1 - 15 of 15 Posts
I have an 06 single cab that I bought for parts. I am nearly done getting what I need off of it. Just let me know what you need and I will see if I have it.
Paint is white with grey interior, driver's side fender and hood are no good. I cut the core support to get the power train out. I also have the fuel tank available.
On most modern vehicles, once you plug in the new cluster it will register your actual miles. I think that's actually stored in the PCM or BCM. That's how it worked on my '01 Pontiac when I replaced the cluster. Sorry. May be different with our trucks, but I think that's how it works once the odometer went digital.
Does it have the tailgate latch and metal bed plate and screws to cover the latch? My son just bought a 2005 that he has a few things he wants to do to it. So I have just joined these forums to search for advice/parts.
Discussion Starter #11
I have actually swapped the BCM and ECM and the mileage didn't change. I am a bit confused on where that info is stored. I am now running the original cluster, BCM with the ECM and ignition switch from my donor truck and the odometer still reads the original mileage.There has to be another component somewhere that stores the odometer mileage.
Discussion Starter #12
Sorry Huck, the latch is broken and the plate is in use. I believe I am going to keep the bed and frame anyway for use as a utility trailer. I think the latch can be bought online for less than $40
Discussion Starter #14
Looks like anywhere from $6 to $100.........
FYI , the Colorado cluster keeps the mileage it had from the original truck. For instance if my truck mileage is 5k and I install a cluster from a truck that has 20k my truck will show 20k and will not add more miles until I surpass 20k. Go figure.:(
1 - 15 of 15 Posts
