1 - 7 of 7 Posts
CALI BOSS
Please read and follow the rules.
Submitting an entry for Photo Of The Month is easy!:
  • Upload or link a good quality (minimum 800x600) non-photoshopped (unless it is part of the contest, ie. HDR) image to the Photo Of The Month Contest Entry Thread
  • You must include the EXIF data from your image to show proof of photo ownership
  • If you are submitting a converted or scanned image from a negative, printed photo or slide, please snap a photo of the actual negative, photo or slide and a legible note with your user name and date to show proof of ownership.
Prize for the winner:
  • Bragging Rights!
Follow the Contest Rules:
  • You must be the owner of the image you are submitting.
  • 1 image will be accepted for entry. You will have time to change your image until the entry deadline.
  • We will not consider low quality images
  • We will not tolerate any pornographic content
  • No Photoshopped pictures unless it is part of the contest! Cropping is accepted.
  • Past winners may enter again every month.
  • You will NOT be up for voting if you get banned.
  • You must have at least 100 posts to vote
  • You have to have been a member of the forum for 1 month at the time that entry closes to enter.
***No Discussions in the entry threads please. Just the link/upload of your photo submission in the entry thread. ***
When to enter for POTM:
- Entries for POTM are taken the final 2 weeks of every month to give you time to take the photos. Voting will start on the 1st of every month and will continue through the entire month. The winner will be announced on the 1st of the following month.
Yes, you will still be able to vote if you have less than 100 posts, but, if you do vote, your vote will be removed from the poll. Polls are checked everyday, and will be amended accordingly. The reasoning behind this action is the same as TOTM.
07/2011 Theme is FIREWORKS
A CREATIVE/ARTISTIC image displaying FIREWORKS, of any shape and/or form will be accepted.
Enter your best FIREWORKS image! The FIREWORKS image can be of single, multiple, unique and/or multicolored bursts. Entries will be accepted until 7/09/2011 @ 11:59pm Pacific Time. Any entries after that time will not qualify and this thread will be locked. The polls will open 7/10/2011 after 12:00am Pacific Time. Entry deadline and contest start date has been adjusted to compensate for the late thread posting
Here is an example of a photo entry:
example removed as per request of owner.
I fucking atoadaso!
EXIF Data
Camera make - Eastman Kodak Company
Camera Model - Kodak Easyshare z8612 IS Digital
Camera Date - 2011.07.04 20.41.04.76
Orientation - normal
Flash - Not used
Focal Length - 44.5mm
Exposure Time - 0.5s (1/2)
Aperture - 6
F Number - f/8
Exposure index - 64
Exposure mode - Manual
Camera maker: Canon
Camera model: Canon EOS DIGITAL REBEL XT
F-stop: f/9
Exposure time: 30 sec
ISO speed: ISO-100
Exposure bias: 0 step
Focal length: 135mm
Max aperture: 4
Metering mode: partial
Flash mode: no flash/compulsary
Exposure Program: shutter priority
Strictly S
Camera make - Canon
Camera Model - Canon EOS 60D
Camera Date - 7-4-2011
Lens-EF-S18-135mm f/3.5-5.6 IS
Flash - none
Focal Length - 18mm
Exposure Time -30.sec
F Number - f/4
focus mode-manual
ISO-100
Camera make : Samsung
Camera model : Samsung BL103
Picture Date : 7/4/2011
Megapixels : 10.2 mp
Millimeter : 18.9 mm
CALI BOSS
Discussion Starter #6
File Name: IMG_9816.jpg
File Size: 168 kb - 1023 x 682
Camera Make: Canon
Camera Model: Canon EOS 50D
Date/Time: 2010:07:04 21:45:06
Resolution: 1023 x 682
Flash Used: No
Focal Length: 42.0mm (35mm equivalent: 67mm)
CCD Width: 22.71mm
Exposure Time: 23.000 s
Aperture: f/11.0
ISO Equiv.: 100
Whitebalance: Manual
Metering Mode: matrix
Exposure: Manual
Exposure Mode: Auto bracketing
_DSC9191 by plays with everything, on Flickr
Taken on July 4, 2010 at 9.24pm CDT (edit)
Posted to Flickr August 15, 2010 at 10.28PM CDT (edit)
Exif data
Camera Nikon D3000
Exposure 13
Aperture f/3.5
Focal Length 18 mm
Focal Length 18.3 mm
ISO Speed 100
Exposure Bias 0 EV
Flash Off, Did not fire
Orientation Horizontal (normal)
X-Resolution 300 dpi
Y-Resolution 300 dpi
Software ViewNX 1.5 W
Date and Time (Modified) 2010:07:07 17:02:24
White Point 0.313 0.329
Primary Chromaticities 0.64 0.33 0.21 0.71 0.15 0.06
YCb Cr Coefficients 0.299 0.587 0.114
YCbCr Positioning Centered
Reference Black White 0 255 0 255 0 255
Exposure Program Not Defined
Date and Time (Original) 2010:07:04 21:24:09
Date and Time (Digitized) 2010:07:04 21:24:09
Max Aperture Value 3.5
Metering Mode Multi-segment
Light Source Unknown
Sub Sec Time 00
Sub Sec Time Original 00
Sub Sec Time Digitized 00
Color Space Uncalibrated
Sensing Method One-chip color area
CFAPattern [Green,Blue][Red,Green]
Custom Rendered Custom
Exposure Mode Auto
White Balance Auto
Digital Zoom Ratio 1
Focal Length In35mm Format 27 mm
Scene Capture Type Standard
Gain Control None
Contrast Normal
Saturation Normal
Sharpness Normal
Subject Distance Range Unknown
Gamma 2.2
Maker Note Version 2.10
ISO 100
Quality Raw
White Balance Auto
Focus Mode Manual
White Balance Fine Tune 0 0
WB_ RBLevels 1.58984375 1.5546875 1 1
Program Shift 0
Exposure Difference 0
ISOSetting 100
Exposure Bracket Value +162113114
Crop Hi Speed Off (3904x2616 cropped to 3904x2616 at pixel 0,0)
Serial Number 3118886
Color Space Adobe RGB
VRInfo Version 0100
Vibration Reduction Off
Active D- Lighting Off
Picture Control Version 0100
Picture Control Name Standard
Picture Control Base Standard
Picture Control Adjust Default Settings
Picture Control Quick Adjust n/a
Sharpness Auto
Contrast Auto
Brightness Normal
Saturation Auto
Hue Adjustment None
Filter Effect n/a
Toning Effect n/a
Toning Saturation n/a
Timezone -06:00
Daylight Savings Yes
Date Display Format M/D/Y
ISOExpansion Off
ISO2 100
ISOExpansion2 Off
Lens Type G VR
Lens 18-55mm f/3.5-5.6
Flash Mode Did Not Fire
Shooting Mode IR Control
Auto Bracket Release Unknown (170)
Lens FStops 5.33
Contrast Curve (Binary data 4 bytes, use -b option to extract)
Shot Info Version 0217
Noise Reduction FPNR
WB_ RGGBLevels 0 0 38657 1
Lens Data Version 0204
Exit Pupil Position 97.5 mm
AFAperture 3.6
Focus Position 0x33
Focus Distance 1.41 m
Lens IDNumber 154
Min Focal Length 18.3 mm
Max Focal Length 55.0 mm
Max Aperture At Min Focal 3.6
Max Aperture At Max Focal 5.7
MCUVersion 156
Effective Max Aperture 3.6
Raw Image Center 1952 1308
Retouch History None
Image Data Size 1052846
Shutter Count 11175
Vari Program Auto(Flash Off)
Multi Exposure Version 0100
Multi Exposure Mode Off
Multi Exposure Shots 0
Multi Exposure Auto Gain Off
High ISONoise Reduction Off
AFInfo2 Version 0100
AFArea Mode Single Area
Auto Focus Off
Primary AFPoint none
AFPoints Used Unknown (00 00 00 00 00 00 00)
File Info Version 0100
Directory Number 100
File Number 9191
Nikon Capture Version ViewNX 1.5 W
Compression JPEG (old-style)
XResolution 300
YResolution 300
Resolution Unit inches
Preview Image Start 10470
Preview Image Length 52835
XMPToolkit Public XMP Toolkit Core 3.5
Creator brian sanders
Rights (C)2009 brian sanders, all rights reserved
Authors Position Nikon digital camera user
Creator Work Telephone 251-786-8267
Usage Terms For consideration only, no reproduction without prior permission
Rating Percent 0
By-line brian sanders
By-line Title Nikon digital camera user
Copyright Notice (C)2009 brian sanders, all rights reserved
1 - 7 of 7 Posts
