1 - 18 of 18 Posts
I have been having some starting issues.
It has happened 3 times now, once back in Dec, and twice this week.
On monday I am getting off work, and I go to start my truck, and the engine turns over, but it wont catch. Now this happened back in Dec, and I wait 20 min, and it started. Well either way I thought it was the battery, so I called over security who can jump me, but it took 20 minutes for them to come, so it started up with a jumper pack anyways.
Then Wednesday, I go to start the truck in my garage same thing. I hook up the jumper pack no go... I have my roommate pull his car over, and try to jump it, no go, I wait the 20 min
It sounds like its flooded, but I thought our trucks could not flood. I have ruled out battery. It started just fine between the monday and wednesday issues (started about 4 times). and has been good since. *knock on wood*
Any ideas?
Anytime i've had starting issues in this truck it was either weak battery OR when the misfiring was getting bad before I had the exhaust valve springs replaced the first time and then when it was getting bad AGAIN when they replaced the heads.
if its flooding its most likely leaking injector/s. if you really think its flooding check fuel pressure. if it holds after priming youre ok. if it drops then you have to find where the leak is.
any lights on? sounds like the security system is acting up.
mine only did this once to me and i knew what caused it......lightning!
NW Surfrider
I would say either flooding..or passlock. Do you get the stupid red lock to come on on your dash?
Discussion Starter #10
After playing around, I found out that it is PassLock screwing me over, I did not notice it, when pass lock is "active" the light flashes, otherwise its solid...(until truck is started)
So my cure of waiting 15min is all I can do until I get passlock disabled.
Discussion Starter #15
11:01:20 PM gerry: I think I remember your thread on 355 about it.... that sucks
11:01:40 PM gerry: sounds like a passlock thing (just a guess)
11:01:45 PM WwRGSwW: Naw
11:01:49 PM WwRGSwW: it was not pass lock
11:01:54 PM WwRGSwW: as the engine was trying to turn over
Damnit! you were right!
1 - 18 of 18 Posts
