1 - 6 of 6 Posts
For awhile my canyon was running hot. At the 3/4 mark. I've changed the fan clutch, thermostat, water pump witch was leaking, and I also changed the temp sensor. It still runs a few clicks above the 1/2 mark. Sometimes closer to the 3/4 mark. Is this normal or should I be worried about a head gasket or something???
That's about normal. Did you use all gm parts? I know it's a pain to have to order them but it's worth the couple bucks and the wait.
Your truck was likely calibrated for the 180F thermostat. They changed to the 194F thermostat in mid-2007, so a new thermostat will run warmer than what you had originally. You can get an exact reading off the ECM with a scangauge which will be much more precise than the instrument cluster. Your truck should be running 195-215F.
TOTM Moderator
I ran into the same thing and even bought the stant "180*" tstat. Which it's not but I made a little shim that'll go in the tstat and drop temps. Currently I'm running about 181-187 with the highest I've seen was 196
I know it’s not apples to apples with a totally different engine, but even with the V8 and a very cramped engine bay, at normal operating temperatures as displayed on my Scangauge, my truck runs at 193deg F at speed with a completely stock cooling system and the lovely Texas heat we are enjoying. If setting parked with no additional air-flow, it will typically climb to around 205 to 207deg F.
1 - 6 of 6 Posts
