1 - 13 of 13 Posts
I have a 2007 GMC Canyon SLE recently purchased I am unable to find the wiring harness t to the transfer case which happens to have been cut out right behind the transmission so none of the connectors are there just a bundle of cut wire. The truck is still in 4wd. Which wires do I need to connect, and to where to send back to 2wd until I can find a wiring Harness. The front drive shaft has been removed. Any help would be greatly appreciated.
I know that. I meant the transfer case is still locked in. If the front drive shaft was installed it would be turning. I want to turn it off. The harness has been a pain to find and I cant even find the connectors that go to the transfer case. I'm trying to turn it where its not in 4hi mode. Back to 2.
Discussion Starter · #4 ·
If anyone can even take a photo of each connector attached to the transfer case for this year model showing the wire colors I could wire it in myself. I think theres only 3 connectors.
Best I could come up with at 0200 hours. Hope it helps at least alittle. This is from a 2010 shop manual.
Transfer Case Encoder Motor
That does help. Thank you. Btw where do I get that manual. Would be very handy.
Your welcome!
I negotiated the shop manual in with the purchase of my truck when I bought it at the dealership.
They are kinda expensive but worth it if you keep vehicles for a long time and perform your own maintenance. Pretty sure they can be picked up on EBay fairly easy.
Good luck with your project.
Welcome to 355nation!
Based on the limited information you supplied I believe this to be a transfercase neutral switch # 98180974 .
1 - 13 of 13 Posts
