1 - 20 of 74 Posts
yes i believe so
G
Discussion Starter · #5 ·
oh. i was jw.. i asked a guy about some projectors and he said that the 04-06was different than the 07 so i didnt know
should be the same i thinkt he only changes made were interior trim slightly and engines
yea i think ive seen under the grille of an 07 before and it was the same braces for the housing
G
Discussion Starter · #9 ·
so they are the same?? could i order the 06 and it will fit. how hard is it to install the projectors
yes they should bolt in no problem. its not to hard. i have them and you have to splice some wires for the halo and LED's to the running lights but thats simple if i can do that.
if you kno how to splice a few wires together it may as well be
yea sure i can tell you what wire to splice with. i can try and take pics but the camara i have sucks bad. but the wire colors should be the same so i can tell you what wire to splice with. with all the LED's that come with these projectors it can be confusing with a wire or 2 coming out of each one.
btw that is a pic of mine in my sig with black housing i also have clear directionals and added the blue bulbs for the blinker and running lights
you may be able to talk to the ebay seller. if you can take a pic tomorrow or something with your grille off i can tell you if theyre the same .
G
Discussion Starter · #18 ·
i asked them and they said not for the 07 but sometimes they dont know what they are talkin about... should i go with clear or blk??
you have the whole chrome thing goin on so i would go with the chrome housing. do you kno how to take off the whole grille?
1 - 20 of 74 Posts
