1 - 12 of 12 Posts
CALI BOSS
Please read and follow the rules.
Submitting an entry for Photo Of The Month is easy!:
  • Upload or link a good quality (minimum 800x600) non-photoshopped (unless it is part of the contest, ie. HDR) image to the Photo Of The Month Contest Entry Thread
  • You must include the EXIF data from your image to show proof of photo ownership
  • If you are submitting a converted or scanned image from a negative, printed photo or slide, please snap a photo of the actual negative, photo or slide and a legible note with your user name and date to show proof of ownership.
Prize for the winner:
  • Bragging Rights!
Follow the Contest Rules:
  • You must be the owner of the image you are submitting.
  • 1 image will be accepted for entry. You will have time to change your image until the entry deadline.
  • We will not consider low quality images
  • We will not tolerate any pornographic content
  • No Photoshopped pictures unless it is part of the contest! Cropping is accepted.
  • Past winners may enter again every month.
  • You will NOT be up for voting if you get banned.
  • You must have at least 100 posts to vote
  • You have to have been a member of the forum for 1 month at the time that entry closes to enter.
***No Discussions in the entry threads please. Just the link/upload of your photo submission in the entry thread. ***
When to enter for POTM:
- Entries for POTM are taken the final 2 weeks of every month to give you time to take the photos. Voting will start on the 1st of every month and will continue through the entire month. The winner will be announced on the 1st of the following month.
Yes, you will still be able to vote if you have less than 100 posts, but, if you do vote, your vote will be removed from the poll. Polls are checked everyday, and will be amended accordingly. The reasoning behind this action is the same as TOTM.
08/2011 Theme is PEOPLE IN MOTION
A CREATIVE/ARTISTIC image displaying a PERSON
(S) in Motion of any shape and/or form will be accepted. The image must show movement.
Enter your best PEOPLE IN MOTION image! The PEOPLE IN MOTION image can be of single, multiple, unique styles of motion. Whether they are dancing, walking running or riding something. Entries will be accepted until 8/09/2011 @ 11:59pm Pacific Time. Any entries after that time will not qualify and this thread will be locked. The polls will open 8/10/2011 after 12:00am Pacific Time. Entry deadline and contest start date has been adjusted to compensate for the late thread posting
Here is an example of a photo entry from photobucket by LauraHiggins_13:
EXIF Data
File Name: IMG_8314.jpg
File Size: 125 kb - 1023 x 696
Camera Make: Canon
Camera Model: Canon EOS 7D
Date/Time: 2011:06:12 03:12:19
Resolution: 1023 x 696
Flash Used: Yes (manual)
Focal Length: 60.0mm (35mm equivalent: 94mm...
CCD Width: 23.04mm
Exposure Time: 0.400 s (1/3)
Aperture: f/16.0
ISO Equiv.: 800
Exposure Bias: -0.67
Whitebalance: Auto
GPS Latitude: S 0d 0m 0.00s
GPS Longitude: W 0d 0m 0.00s
Comment: ݯ
Example 2 from Photobucket by emflem10:
EXIF Data
File Name: motion.jpg
File Size: 160 kb - 1024 x 868
Camera Make: NIKON CORPORATION
Camera Model: NIKON D50
Date/Time: 2010:11:25 19:35:22
Resolution: 1024 x 868
Flash Used: No
Focal Length: 30.0mm (35mm equivalent: 45mm...
Exposure Time: 0.100 s (1/10)
Aperture: f/29.0
ISO Equiv.: 800
Whitebalance: Manual
Metering Mode: matrix
Exposure: shutter priority (semi-auto)
CFA Pattern: 1, 2, 0, 1
Contrast: Normal
Custom Rendered: Normal process
Date Time Digitized: 2011:02:04 19:45:42
Date Time Original: 2011:02:04 19:45:42
Digital Zoom Ratio: 1
Exposure Bias Value: 0
Exposure Mode: Manual exposure
Exposure Program: Manual
Exposure Time: 1 / 200
File Source: DSC
Flash: Flash did not fire
FNumber: 2.8
Focal Length: 70
Focal Length In 35mm Film: 105
Gain Control: Low gain up
ISO Speed Ratings: 800
Light Source: unknown
Max Aperture Value: 3
Metering Mode: Pattern
Saturation: Normal
Scene Capture Type: Standard
Scene Type: A directly photographed image
Sensing Method: One-chip color area sensor
Sharpness: Hard
Subject Distance Range: unknown
Sub-second Time: 50
Sub-second Time Digitized: 50
Sub-second Time Original: 50
User Comment:
White Balance: Auto white balance
_ImageStabilization: 0
AFInfo: 0.4673508, 0.2823034, 0.06529851, 0.04213483, n, 0.6539179, 0.4613764, 0.02798508, 0.07724719, n, 0.4673508, 0.6755618, 0.06529851, 0.04213483, n, 0.2061567, 0.4613764, 0.02798508, 0.07724719, n, 0.7658582, 0.4613764, 0.02798508, 0.07724719, n, 0.4626866, 0.4747191, 0.07462686, 0.0505618, F, 0.318097, 0.3349719, 0.02798508, 0.07724719, n, 0.318097, 0.4613764, 0.02798508, 0.07724719, n, 0.6539179, 0.587781, 0.02798508, 0.07724719, n, 0.318097, 0.587781, 0.02798508, 0.07724719, n, 0.6539179, 0.3349719, 0.02798508, 0.07724719, n
FlashCompensation: 0
Focus Distance: 8.413953
Focus Mode: 1
ImageNumber: 61148
LensID: -1276668788927608058
Lens Info: 70, 200, 2.8, 2.8
Lens Model: Sigma 70-200mm F2.8 EX APO DG Macro HSM II
SerialNumber: 3174750
CALI BOSS
BUMP for MORE entries!!
EXIF Data
File Name: Jordon in Motion.jpg
Camera Make: NIKON
Camera Model: COOLPIX L120
Date/Time: 7/18/2011 6:38pm
Exposure Time: 1/2 sec
ISO Speed: ISO-400
Focal Length: 4 mm
Max Aperture: 3.2
Flash: Auto.Red-Eye
35mm Focal Length: 25
Dimensions: 4320x3240
Width: 4320 pixels
Height: 3240 pixels
Horizontal Resolution: 300 dpi
Vertical Resolution: 300 dpi
Bit Depth: 24
Resolution Unit: 2
Color Representation: sRGB
Compressed bits/pixel: 4
DSC_5935 by plays with everything, on Flickr
Exif data
Camera Nikon D3000
Exposure 0.1 sec (1/10)
Aperture f/2.5
Focal Length 35 mm
Focal Length 35.6 mm
ISO Speed 100
Exposure Bias -2/3 EV
Flash On, Return detected
Orientation Horizontal (normal)
X-Resolution 300 dpi
Y-Resolution 300 dpi
Software Nikon Transfer 1.5 W
Date and Time (Modified) 2010:05:05 21:52:06
YCbCr Positioning Centered
Exposure Program Aperture-priority AE
Date and Time (Original) 2010:05:02 19:39:14
Date and Time (Digitized) 2010:05:02 19:39:14
Max Aperture Value 1.7
Metering Mode Multi-segment
Light Source Unknown
Sub Sec Time 50
Sub Sec Time Original 50
Sub Sec Time Digitized 50
Color Space Uncalibrated
Sensing Method One-chip color area
CFAPattern [Green,Blue][Red,Green]
Custom Rendered Normal
Exposure Mode Auto
White Balance Auto
Digital Zoom Ratio 1
Focal Length In35mm Format 52 mm
Scene Capture Type Landscape
Gain Control None
Contrast Normal
Saturation Normal
Sharpness Normal
Subject Distance Range Unknown
Maker Note Version 2.10
ISO 100
Quality Basic
White Balance Auto
Focus Mode AF-C
Flash Setting Slow
Flash Type Optional,Ttl
White Balance Fine Tune 0 0
WB_ RBLevels 2.01171875 1.02734375 1 1
Program Shift 0
Exposure Difference 0
Flash Exposure Comp 0
ISOSetting 100
Image Boundary 0 0 3872 2592
Exposure Bracket Value +162113114
Crop Hi Speed Off (3904x2616 cropped to 3904x2616 at pixel 0,0)
Serial Number 3118886
Color Space sRGB
VRInfo Version 0100
Vibration Reduction Off
Active D- Lighting Auto
Picture Control Version 0100
Picture Control Name Landscape
Picture Control Base Landscape
Picture Control Adjust Default Settings
Picture Control Quick Adjust Normal
Sharpness 4
Contrast Normal
Brightness Normal
Saturation Normal
Hue Adjustment None
Filter Effect n/a
Toning Effect n/a
Toning Saturation n/a
Timezone -06:00
Daylight Savings Yes
Date Display Format M/D/Y
ISOExpansion Off
ISO2 100
ISOExpansion2 Off
Lens Type G
Lens 35mm f/1.8
Flash Mode Fired, External
Shooting Mode Delay
Auto Bracket Release Manual Release
Lens FStops 7.33
Shot Info Version 0217
Noise Reduction Off
WB_ RGGBLevels 0 0 515 256
Lens Data Version 0204
Exit Pupil Position 120.5 mm
AFAperture 1.8
Focus Position 0x33
Focus Distance 2.51 m
Lens IDNumber 159
Min Focal Length 35.6 mm
Max Focal Length 35.6 mm
Max Aperture At Min Focal 1.8
Max Aperture At Max Focal 1.8
MCUVersion 161
Effective Max Aperture 1.8
Retouch History None
Image Data Size 671176
Shutter Count 7973
Flash Info Version 0103
External Flash Firmware 2.05 (SB-600)
External Flash Flags [0], [2], Wide Flash Adapter
Flash Commander Mode Off
Flash Control Mode iTTL-BL
Flash Focal Length 14 mm
Flash Group AControl Mode Off
Flash Group BControl Mode Off
Flash Group CControl Mode Off
Flash Group AExposure Comp 0
Flash Group BExposure Comp 0
Flash Group CExposure Comp 0
Multi Exposure Version 0100
Multi Exposure Mode Off
Multi Exposure Shots 0
Multi Exposure Auto Gain Off
High ISONoise Reduction Off
AFInfo2 Version 0100
AFArea Mode Unknown (9)
Auto Focus Unknown (2)
Primary AFPoint Center
AFPoints Used Unknown (01 00 00 00 00 00 00)
File Info Version 0100
Directory Number 101
File Number 5935
Compression JPEG (old-style)
XResolution 72
YResolution 72
Resolution Unit inches
Preview Image Start 14246
Preview Image Length 25858
XMPToolkit Public XMP Toolkit Core 3.5
Creator brian sanders
Rights (C)2009 brian sanders, all rights reserved
Authors Position Nikon digital camera user
Creator Work Telephone 251-786-8267
Usage Terms For consideration only, no reproduction without prior permission
Rating Percent 0
By-line brian sanders
By-line Title Nikon digital camera user
Copyright Notice (C)2009 brian sanders, all rights reserved
taken with a htc evo
everything was on auto
CALI BOSS
CALI BOSS
Discussion Starter #8
EXIF Data
File Name: IMG_37511.jpg (Edit)
File Size: 274 kb - 1023 x 682
Camera Make: Canon
Camera Model: Canon EOS 50D
Date/Time: 2011:05:20 20:53:18
Resolution: 1023 x 682
Flash Used: No
Focal Length: 17.0mm (35mm equivalent: 27mm...
CCD Width: 22.71mm
Exposure Time: 0.800 s
Aperture: f/2.8
ISO Equiv.: 200
Exposure: aperture priority (semi-auto)
im not fancy enuff to get a digital camera... i use my cell for everything...
make an exception:shrug:
CALI BOSS
Discussion Starter #10
Then you need to adjust your photobucket settings to make the images upload at a higher resolution (800x600 or larger) and use the Photo Info link provided when viewing the single image to get the photo's EXIF Data
ummmmm r u running late postng the poll?
CALI BOSS
Discussion Starter #12
I was waiting for BLUE STEEL to upload a larger image and was hoping there would be more entries.
1 - 12 of 12 Posts
