1 - 20 of 21 Posts
trying today to pre assembly my hubs and rotors and they just won't fit
any ideas?
seems is hub is a little too big or the rotors is a little too small
sorry
when i go to assembly the rotor hub assembly after feeding through ABS wire and trying to mount the rotor to hub it seems like the rotor wasn't cut out big enough for the hub to slide through
grabbed the pic from the how to
and when the rotor goes down it won't go back the flange where i mounts to the spindle
Discussion Starter · #5 ·
spindles are stock for now
but the CST's i will be running fit all model years
I'm running a 06 hub with 09 rotor
maniac mechanic
Fixed my other post I misunderstood your issue from reading too fast. I thought the rotor was hitting the spindle as you were installing the hub to the spindle.
Also how much does it seem to be off? You could just have a sloppy casting on the hub, if it's minimal just file it until it fits.
Discussion Starter · #8 ·
this is how its stuck
maniac mechanic
Looks like those rotors were casted badly without enough clearance. I would return them and buy them from someone else.
The flange on the hub is the same for all years so it has to be a manufacturer flaw from the maker of the rotor. Bring the hub in and explain when you return them so they can call and alert the manufacturer.
Are both the rotors and the hub supposed to have the bolt hole threaded, seems like that would cause a problem bolting them together.
Discussion Starter · #13 ·
just the rotor is threaded for the rotor to hub mounting and then the hub i threaded in the case of hub to spindle mount
and i used Centric Rotors
Discussion Starter · #15 ·
so
i dove deeper and found that the Z71 hubs at my local orielly fit
looks like imma have to go with them
maniac mechanic
I would still swap those rotors back out, the holes on them are off center on the flange and look awful. They shouldn't give you any trouble returning them.
Also if you are using z71 make sure they are 2wd the 4wd will fall apart in a couple days without the cv and axle nut preloading them.
Discussion Starter · #17 ·
i just picked up a z71 set
Discussion Starter · #18 ·
i tried 6 other sets of Z85 hubs and no avail
i tried those hubs with the rotors at those stores as well as mine n no go
maniac mechanic
The rotors are definitely the issue. Even if you find a hub they fit on, I suspect they will not run true and cause vibration while braking because of the way the bolt pattern is set in comparison to the stopping surface.
1 - 20 of 21 Posts
