I added exactly 5 quarts, and it reads high but it will just overflow out the tubes.
Changed every 2 years or 40-50k miles depending on which comes first. Usually 50k miles. Think this is the 3rd change with dex vi or equivalent. Maybe 4th. Didn't have the squeak till yesterday.How often do you change your transmission fluid? Is this the first time?
There goes my guess. Sounds like you're on top of things. :thumbup:Changed every 2 years or 40-50k miles depending on which comes first. Usually 50k miles. Think this is the 3rd change with dex vi or equivalent. Maybe 4th. Didn't have the squeak till yesterday.
I did however throw down another 110 miles today and will do the same tomorrow, I'll check and see if it still does it after that.
If you include the torque converter it's really 8 quarts.2005 service manual says on a pan drop and refill to add 5 quarts.
5 quarts were added.
Transmission was checked hot, after sitting and shifting though gears as spelled out. It's high.
So, either the service manual is wrong
They are using some strange version of a quart that isn't native to the US
Or, it takes time for all the air to work itself out of the lines and it will read normal after a few more miles are put on it
Or...someone gets to drain fluid from the transmission even though everything says add 5qts.
If it's the last one, I'm dickpunching the service manual writers.
Still want to know wtf the squeak is/was...didn't check to see if it was there tonight.
