1 - 12 of 12 Posts
Damm, there not cheap. once you separate the good ones
from the bad the price jumps up a lot. I found 2 good companys
Harland Sharp and Lanati Voodoo that are priced right around
$400.00 bucks. most other top brands are way over priced.
Yeah, they're not cheap!
Comp sells a set of 8 pro magnums for $220.
When I do my cam I think I'm gonna just do the trunnion upgrade for $150.
Do you have full roller rockers now Al. ? I would let it settle in for a couple thousand miles along with a few other bolt ons for the cost of the 1.8's. Harmonic Balancer/Underdrive Pulley - slponline.com. Get the efan installed and an exhaust that will allow you to take the cats off real quick like. Retune and dyno with the AC belt off. Here's to more power. I don't know if 350whp is your goal but that should put you in that range with that cam. Oh and you will need a transmission cooler.
Discussion Starter · #4 ·
Joe, already have the SLP pulley, not going to mess with the cats, only have the small
front ones on.have a trans cooler on the workbench. working on putting on the e-fan.
all my dyno runs will be in full street trim, that's how i race. the rockers are the
way to go to get what i want.
Tony, where did you see Comp rollers that cheap ? 500.00 to 600.00 for LS bolt
thru rockers. I did the trunnion upgrade,and push rods. cool deal
X2 no need for 1.8 rockers they're overkill on our engines. Trunion upgrade is more than enough protection for our rockers.
Discussion Starter · #8 ·
I already did the cam,springs, push rods and trunnions, just looking to bump my
int side a little more on the cam.
Soul, thanks. they won't fit with stock valve covers. only need 8 for the int side.
What cam do u have?
Discussion Starter · #10 ·
a small Comp VVT. 210/224--.556/.568--114 LCL
Comp screwed me on this cam,they recommended the wrong cam
for me, this cam is for a L92 6.2 with square port heads. they don't
have a 5.3 VVT cam. it's a long story we talked about before on
there.
Sell it eliminate the vvt junk buy a regular cam 224/230 581 591 112+2 and a 34-3600 stall with 3 73s u will be golden
Discussion Starter · #12 ·
this is a DD and tow vehicle, also long distance driver. that's why no conv or 3:73's
had all that stuff in my last truck. not very fun on long trips and a real gas sucker.
1 - 12 of 12 Posts
