1 - 11 of 11 Posts
CALI BOSS
Please read and follow the rules.
Submitting an entry for Photo Of The Month is easy!:
  • Upload or link a good quality (minimum 800x600) non-photoshopped (unless it is part of the contest, ie. HDR) image to the Photo Of The Month Contest Entry Thread
  • You must include the EXIF data from your image to show proof of photo ownership
  • If you are submitting a converted or scanned image from a negative, printed photo or slide, please snap a photo of the actual negative, photo or slide and a legible note with your user name and date to show proof of ownership.
Prize for the winner:
  • Bragging Rights!
Follow the Contest Rules:
  • You must be the owner of the image you are submitting.
  • 1 image will be accepted for entry. You will have time to change your image until the entry deadline.
  • We will not consider low quality images
  • We will not tolerate any pornographic content
  • No Photoshopped pictures unless it is part of the contest! Cropping is accepted.
  • Past winners may enter again every month.
  • You will NOT be up for voting if you get banned.
  • You must have at least 100 posts to vote
  • You have to have been a member of the forum for 1 month at the time that entry closes to enter.
***No Discussions in the entry threads please. Just the link/upload of your photo submission in the entry thread. ***
When to enter for POTM:
- Entries for POTM are taken the final 2 weeks of every month to give you time to take the photos. Voting will start on the 1st of every month and will continue through the entire month. The winner will be announced on the 1st of the following month.
Yes, you will still be able to vote if you have less than 100 posts, but, if you do vote, your vote will be removed from the poll. Polls are checked everyday, and will be amended accordingly. The reasoning behind this action is the same as TOTM.
10/2011 Theme is SUNSET
A CREATIVE/ARTISTIC image displaying a SUNSET. The image must show the sun setting in the background.
Enter your best SUNSET image! The SUNSET image is self-explanatory. Entries will be accepted until 10/14/2011 @ 11:59pm Pacific Time. Any entries after that time will not qualify and this thread will be locked. The polls will open 10/15/2011 after 12:00am Pacific Time. Entry deadline and contest start date has been adjusted to compensate for the late thread posting
Here is an example of a photo entry from photobucket by aadhilnet:
EXIF Data
File Name: 30.jpg
File Size: 97 kb - 1024 x 576
Camera Make: NIKON CORPORATION
Camera Model: NIKON D300
Date/Time: 2008:10:02 18:11:35
Resolution: 1024 x 576
Flash Used: No
Focal Length: 10.0mm (35mm equivalent: 15mm...
Exposure Time: 0.0080 s (1/125)
Aperture: f/5.6
ISO Equiv.: 100
Exposure Bias: 2.00
Whitebalance: Auto
Metering Mode: matrix
Exposure: program (auto)
Here is an example of a photo entry from photobucket by lo_torres:
EXIF Data
File Name: P9240031.jpg
File Size: 276 kb - 1024 x 635
Camera Make: OLYMPUS IMAGING CORP.
Camera Model: SP800UZ
Date/Time: 2011:09:24 19:07:12
Resolution: 1024 x 635
Flash Used: No
Focal Length: 8.9mm (35mm equivalent: 49mm)
Exposure Time: 0.0010 s (1/1000)
Aperture: f/4.4
ISO Equiv.: 50
Whitebalance: Auto
Exposure: Creative Program
jumping in early on this one. the only windmill that is close and great for sunset shots.
File Name: IMG_0495.jpg (Edit)
File Size: 221 kb - 1024 x 768
Camera Make: Canon
Camera Model: Canon PowerShot SX20 IS
Date/Time: 2010:08:17 20:20:20
Resolution: 1024 x 768
Flash Used: No
Focal Length: 19.8mm (35mm equivalent: 115m...
CCD Width: 6.20mm
Exposure Time: 0.0063 s (1/160)
Aperture: f/4.5
ISO Equiv.: 160
Whitebalance: Manual
Exposure Mode: Auto bracketing
CALI BOSS
Discussion Starter #4
Go to your pic in photobucket and click on Data on the bottom right column to get it
_DSC3768 by plays with everything, on Flickr
Exif data
Camera Nikon D3000
Exposure 0.005 sec (1/200)
Aperture f/16.0
Focal Length 55 mm
Focal Length 55.0 mm
ISO Speed 100
Exposure Bias 0 EV
Flash No Flash
Orientation Horizontal (normal)
X-Resolution 300 dpi
Y-Resolution 300 dpi
Software ViewNX 1.5 W
Date and Time (Modified) 2011:05:02 22:36:57
White Point 0.313 0.329
Primary Chromaticities 0.64 0.33 0.21 0.71 0.15 0.06
YCb Cr Coefficients 0.299 0.587 0.114
YCbCr Positioning Centered
Reference Black White 0 255 0 255 0 255
Exposure Program Manual
Date and Time (Original) 2011:01:02 17:01:16
Date and Time (Digitized) 2011:01:02 17:01:16
Max Aperture Value 4.0
Metering Mode Multi-segment
Light Source Fine Weather
Sub Sec Time 00
Sub Sec Time Original 00
Sub Sec Time Digitized 00
Color Space Uncalibrated
Sensing Method One-chip color area
CFAPattern [Green,Blue][Red,Green]
Custom Rendered Normal
Exposure Mode Manual
White Balance Manual
Digital Zoom Ratio 1
Focal Length In35mm Format 82 mm
Scene Capture Type Standard
Gain Control None
Contrast Normal
Saturation Normal
Sharpness Normal
Subject Distance Range Unknown
Gamma 2.2
Maker Note Version 2.10
ISO 100
Quality Raw
White Balance Sunny
Focus Mode AF-S
White Balance Fine Tune 0 0
WB_ RBLevels 1.8515625 1.34765625 1 1
Program Shift 0
Exposure Difference +0.2
ISOSetting 100
Exposure Bracket Value +162113114
Crop Hi Speed Off (3904x2616 cropped to 3904x2616 at pixel 0,0)
Serial Number 3118886
Color Space Adobe RGB
VRInfo Version 0100
Vibration Reduction Off
Active D- Lighting Off
Picture Control Version 0100
Picture Control Name Standard
Picture Control Base Standard
Picture Control Adjust Default Settings
Picture Control Quick Adjust Normal
Sharpness 3
Contrast Normal
Brightness Normal
Saturation Normal
Hue Adjustment None
Filter Effect n/a
Toning Effect n/a
Toning Saturation n/a
Timezone -06:00
Daylight Savings Yes
Date Display Format M/D/Y
ISOExpansion Off
ISO2 100
ISOExpansion2 Off
Lens Type G
Lens 55-200mm f/4-5.6
Flash Mode Did Not Fire
Shooting Mode Continuous
Auto Bracket Release Unknown (170)
Lens FStops 5.00
Contrast Curve (Binary data 4 bytes, use -b option to extract)
Shot Info Version 0217
Noise Reduction Off
WB_ RGGBLevels 0 0 55809 1
Lens Data Version 0204
Exit Pupil Position 62.1 mm
AFAperture 4.1
Focus Position 0x06
Focus Distance 17.78 m
Lens IDNumber 137
Min Focal Length 55.0 mm
Max Focal Length 201.6 mm
Max Aperture At Min Focal 4.0
Max Aperture At Max Focal 5.7
MCUVersion 139
Effective Max Aperture 4.0
Raw Image Center 1952 1308
Retouch History None
Image Data Size 6465281
Shutter Count 15736
Multi Exposure Version 0100
Multi Exposure Mode Off
Multi Exposure Shots 0
Multi Exposure Auto Gain Off
High ISONoise Reduction Off
AFInfo2 Version 0100
AFArea Mode Auto-area AF
Auto Focus Unknown (2)
Primary AFPoint Unknown (8)
AFPoints Used Unknown (e8 06 00 00 00 00 00)
File Info Version 0100
Directory Number 101
File Number 3768
Nikon Capture Version ViewNX 1.5 W
Compression JPEG (old-style)
XResolution 300
YResolution 300
Resolution Unit inches
Preview Image Start 8712
Preview Image Length 32811
XMPToolkit Public XMP Toolkit Core 3.5
Creator brian sanders
Rights (C)2009 brian sanders, all rights reserved
Authors Position Nikon digital camera user
Creator Work Telephone 251-786-8267
Usage Terms For consideration only, no reproduction without prior permission
Rating Percent 0
By-line brian sanders
By-line Title Nikon digital camera user
Copyright Notice (C)2009 brian sanders, all rights reserved
CALI BOSS
Discussion Starter #6
File Name: IMG_4237.jpg
File Size: 97 kb - 1023 x 682
Camera Make: Canon
Camera Model: Canon EOS 50D
Date/Time: 2009:06:27 21:00:24
Resolution: 1023 x 682
Flash Used: No
Focal Length: 77.0mm (35mm equivalent: 122m...
CCD Width: 22.71mm
Exposure Time: 0.125 s (1/8)
Aperture: f/22.0
ISO Equiv.: 200
Metering Mode: spot
Exposure: Manual
Camera Maker: Canon
Camera Model: Canon PowerShot SD800 IS
F-stop: f/2.8
Exposure time: 1/3 sec.
ISO speed:
Exposure bias: -0.3 step
Focal length: 5mm
Max aperture: 2.96875
Metering Mode: Pattern
Subject distance:
Flash mode: No flash, compulsory
Flash energy:
35mm focal length:
Texas Yoda!!!!
File Name: IMG_3882.jpg (Edit)
File Size: 167 kb - 1023 x 764
Camera Make: Apple
Camera Model: iPhone 4
Date/Time: 2011:10:01 19:22:56
Resolution: 1023 x 764
Flash Used: No
Focal Length: 3.9mm
Exposure Time: 0.033 s (1/30)
Aperture: f/2.8
ISO Equiv.: 80
Whitebalance: Auto
Metering Mode: spot
GPS Latitude: N 32d 46m 33.60s
GPS Longitude: W 96d 45m 28.80s
GPS Altitude: 10664m
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
File Name: 019 JPG
File Size: 981 kb
Camera Make: Fugi
Camera Model: FinePix S1500
Date/Time: 10-01-11 6:35PM
Resolution:
Flash Used: No
Focal Length: 17mm
CCD Width:
Exposure Time: 1/300 sec
Aperture: 2.97
ISO Equiv.: 200
Whitebalance: auto
Exposure: Normal
Exposure Mode: auto
File Name: DSC_0800.jpg (Edit)
File Size: 98 kb - 1023 x 680
Camera Model: NIKON D50
Date/Time: 2009:06:27 09:06:20
Resolution: 1023 x 680
Flash Used: No
Focal Length: 28.0mm (35mm equivalent: 42mm...
Exposure Time: 0.0100 s (1/100)
Aperture: f/5.0
Whitebalance: Auto
File Name: IMG_0959.jpg
File Size: 159 kb - 1023 x 682
Camera Make: Canon
Camera Model: Canon EOS 60D
Date/Time: 2011:09:29 08:43:06
Flash Used: No
Focal Length: 120.0mm (35mm equivalent: 188...
CCD Width: 22.99mm
Exposure Time: 0.250 s (1/4)
Aperture: f/5.6
ISO Equiv.: 3200
Whitebalance: Auto
1 - 11 of 11 Posts
