1 - 7 of 7 Posts
Formerly Metal_EMT
Use wire loom and go along the top of the framerail on the driver side. There's a harness there you can run your cabling along. Then it can come up right by the battery.
Good advice, this is really your only option.
Don't fail to include a fuse at the battery.
I would advise running heavier gauge wire than you think you need, once you have power back in the bed you'll come up with more ideas on how to use it.
I installed a fuse box under the bedrail and it has worked great for two years (I do have a folding tonneau, but it has been fine in the rain).
Sent from AutoGuide.com App
Discussion Starter · #6 ·
Thanks for the tips guys! I ended up running power wire inside the factory wire loom along the top of the frame rail. I put 1 18" led strip shining into the bed and 1 inside the toolbox, with a momentary push button so when I open the toolbox, the lights come on, and close it to turn them off.
Neat thinking !!! :salute:
1 - 7 of 7 Posts
