1 - 5 of 5 Posts
Thanks for the add! Picked up my first Colorado two weeks ago it’s a 2008 2.9L 5 speed manual bought it as a no start, was told it only needed a starter although I knew It wouldn’t need just that. I was also told the camshaft sensor was replaced but still wouldn’t run. Since purchase I have since then put a starter, purge valve, ignition switch, and a knock sensor pigtail. Truck still won’t crank. Any ideas of what it might be?!? Also tried to plug up a scanner but it wouldn’t read anything and just say error.
Discussion Starter · #2 ·
Any help would be appreciated I’ve been looking everywhere for an answer like fb groups and forums and no one seems to know. Any response would be greatly appreciated I can provide a video of exactly what’s going on also if my wording doesn’t help. Someone please help!!!
I see no check engine light on,No power to ECM or bad ECM.This could be a bad under hood fuse block also.Need to check power and ground to ecm with key on.Good Luck!
When mine did this, it was a bad alternator. It through all kinds of codes (including “U” codes related to the computer)
1 - 5 of 5 Posts
