1 - 10 of 10 Posts
Here is an all in one thread for recall notices published by GM on the NHTSA webpage; currently there are 3 listed for 2004-2012. I will continue to search and see if there are other notices out there.
Take a minute to review. I would urge you to then see if your truck has had these deficiencies corrected. This information is also good to be armed with if your looking at buying a used 355.
**Run your VIN to see if the recall repairs on your vehicle have been completed** http://www.safercar.gov/Vehicle+Owners
REF: http://www-odi.nhtsa.dot.gov/owners/SearchResults
___________________________________________________________________________
Report Receipt Date: DEC 19, 2012
NHTSA Campaign Number: 12V594000
Component(s): LATCHES/LOCKS/LINKAGES
All Products Associated with this Recall expand
Details close
14 Associated Documents expand
Manufacturer: General Motors LLC
SUMMARY:
General Motors is recalling certain model year 2010-2012 Chevrolet Colorado and GMC Canyon vehicles manufactured from November 9, 2009, through August 28, 2012, for failing to comply with the requirements of Federal Motor Vehicle Safety Standard No. 113, "Hood Latch System." The hood may be missing the secondary hood latch.
CONSEQUENCE:
If the primary hood latch is not engaged, the hood could open unexpectedly. During vehicle operation, this could obstruct the view of the driver and increase the risk of a crash.
REMEDY:
General Motors will notify owners and instruct them to inspect their vehicle for the presence of a secondary hood latch. Dealers will replace the hood on any affected vehicles, free of charge. The recall is expected to begin on January 17, 2013. Owners may contact Chevrolet at 1-800-630-2438 or GMC at 1-866-996-9463.
NOTES:
GM's number for this campaign is 12319. Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Page break ---------------------------------------------------------------------------
Report Receipt Date: NOV 17, 2011
NHTSA Campaign Number: 11V552000
Component(s): SEAT BELTS
Details close
11 Associated Documents expand
Manufacturer: GENERAL MOTORS LLC
SUMMARY:
GENERAL MOTORS (GM) IS RECALLING CERTAIN MODEL YEAR 2012 CHEVROLET COLORADO AND GMC CANYON VEHICLES, MANUFACTURED FROM SEPTEMBER 9, 2011, THROUGH OCTOBER 19, 2011, FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NUMBER 208, "OCCUPANT CRASH PROTECTION." THESE VEHICLES MAY HAVE BEEN PRODUCED WITH DRIVER SAFETY BELT BUCKLE ELECTRICAL CONNECTOR TERMINALS THAT DO NOT FIT SNUGLY WITH THE CONNECTOR PINS, CAUSING THE CONNECTION TO BE INTERMITTENT.
CONSEQUENCE:
THE LOOSE CONNECTIONS MAY CAUSE THE DRIVER TO NOT RECEIVE A VISUAL OR AUDIBLE WARNING THAT THE DRIVER SEAT BELT IS NOT FASTENED, THEREBY INCREASING THE RISK OF PERSONAL INJURY IN THE EVENT OF A CRASH.
REMEDY:
GM WILL NOTIFY OWNERS AND DEALERS WILL REPLACE THE SEAT BELT BUCKLE ELECTRICAL CONNECTOR TERMINALS FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR BEFORE DECEMBER 7, 2011. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438 AND GMC AT 1-866-996-9463.
NOTES:
GM'S SAFETY RECALL CAMPAIGN NUMBER IS 11322. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Receipt Date: JUN 28, 2011
NHTSA Campaign Number: 11V337000
Component(s): POWER TRAIN
Details close
10 Associated Documents expand
SUMMARY:
GENERAL MOTORS IS RECALLING CERTAIN MODEL YEAR 2011 CHEVROLET COLORADO AND GMC CANYON PASSENGER VEHICLES EQUIPPED WITH A 2.9 OR 3.7 LITER ENGINE AND A FOUR-SPEED AUTOMATIC TRANSMISSION FOR FAILING TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO 102, "TRANSMISSION SHIFT LEVER SEQUENCE, STARTER INTERLOCK, AND TRANSMISSION BRAKING EFFECT," AND FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 114, "THEFT PROTECTION." THESE VEHICLES MAY HAVE BEEN BUILT WITH AN AUTOMATIC TRANSMISSION ADJUSTMENT CLIP THAT MAY NOT RETAIN THE SHIFT CABLE IN THE CORRECT POSITION. IF THE SHIFT CABLE IS NOT IN THE CORRECT POSITION, THE PRNDL SHIFT LEVER MAY NOT ACCURATELY REFLECT THE POSITION OF THE TRANSMISSION GEAR. THE DRIVER COULD MOVE THE SHIFTER TO "PARK" AND REMOVE THE IGNITION KEY, BUT THE TRANSMISSION GEAR MAY NOT BE IN "PARK."
CONSEQUENCE:
THE DRIVER MAY NOT BE ABLE TO RESTART THE VEHICLE, AND THE VEHICLE COULD ROLL AWAY AS THE DRIVER OR OTHER OCCUPANTS EXIT THE VEHICLE OR HAVE EXITED, RESULTING IN THE POSSIBILITY OF THE VEHICLE STRIKING THEM OR SOMEONE AROUND THE VEHICLE, OR COULD RESULT IN A CRASH WITHOUT PRIOR WARNING.
REMEDY:
GM DEALERS WILL INSTALL A NEW AUTOMATIC TRANSMISSION ADJUSTMENT CLIP FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT JULY 19, 2011. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438 AND GMC AT 1-866-996-9463.
NOTES:
GM'S SAFETY RECALL NO. 11181. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Receipt Date: MAY 06, 2011
NHTSA Campaign Number: 11V276000
Component(s): VISIBILITY
Details close
12 Associated Documents expand
SUMMARY:
GENERAL MOTORS IS RECALLING CERTAIN MODEL YEAR 2011 CHEVROLET COLORADO AND GMC CANYON VEHICLES MANUFACTURED FROM SEPTEMBER 22, 2010, THROUGH NOVEMBER 5, 2010. SOME OF THESE VEHICLES HAVE THE CONDITION IN WHICH THE WINDSHIELD WIPER MOTOR CRANK ARM NUT MAY NOT BE TIGHTENED TO SPECIFICATION. WHEN THE WIPERS ARE OPERATED WITH A BUILD-UP OF SNOW OR ICE, OR IF THE WIPERS ARE OPERATED ON A DRY WINDSHIELD, THE NUT COULD LOOSEN. IF THERE IS SUFFICIENT LOOSENING OF THE NUT, THE WIPERS COULD BECOME INOPERATIVE.
CONSEQUENCE:
DRIVER VISIBILITY COULD BE REDUCED INCREASING THE RISK OF A CRASH.
REMEDY:
DEALERS WILL SECURE THE WIPER MOTOR CRANK ARM NUT FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR BEFORE MAY 11, 2011. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438, GMC AT 1-866-996-9463 OR WWW.GMOWNERCENTER.COM.
NOTES:
GM'S SAFETY RECALL NO. 11095. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Receipt Date: JAN 06, 2011
NHTSA Campaign Number: 11V007000
Component(s): SUSPENSION
Details close
20 Associated Documents expand
Manufacturer: GENERAL MOTORS CORP.
SUMMARY:
GENERAL MOTORS IS RECALLING CERTAIN MODEL YEAR 2011 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT; CHEVROLET AVALANCHE, COLORADO, EXPRESS, SILVERADO, SUBURBAN, TAHOE; AND GMC CANYON, SIERRA, SAVANA, YUKON AND YUKON XL VEHICLES. THE REAR AXLE CROSS PINS WERE NOT PROPERLY HEAT TREATED AND COULD FRACTURE AND BECOME DISPLACED WITHIN THE REAR AXLE. SHOULD THE PIN SHIFT OUT OF POSITION, IT COULD CREATE AN INTERFERENCE CONDITION AND CAUSE THE REAR AXLE TO LOCK.
CONSEQUENCE:
THE DRIVER MAY NOT BE ABLE TO MAINTAIN DIRECTIONAL CONTROL OF THE VEHICLE AND A CRASH COULD OCCUR WITHOUT WARNING.
REMEDY:
DEALERS WILL INSTALL A NEW REAR AXLE CROSS PIN FREE OF CHARGE. THE SAFETY RECALL BEGAN ON JANUARY 11, 2011. OWNERS MAY CONTACT CADILLAC AT 1-866-982-2339, CHEVROLET AT 1-800-630-2438, GMC AT 1-866-996-9463 AND AT THE OWNER CENTER AT WWW.GMOWNERCENTER.COM.
NOTES:
THIS RECALL CAMPAIGN IS AN EXPANSION TO 10V-643. GM'S SAFETY RECALL NO. 10426A. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Receipt Date: NOV 18, 2010
NHTSA Campaign Number: 10V575000
Component(s): CHILD SEAT
Details close
18 Associated Documents expand
SUMMARY:
GM IS RECALLING CERTAIN MODEL YEAR 2004-2011, CHEVROLET COLORADO, GMC CANYON, MODEL YEAR 2006, ISUZU I-280/I-350, AND MODEL YEAR 2007-2008, I-290/I-370, REGULAR CAB VEHICLES AND EXTENDED CAB VEHICLES WITHOUT A REAR SEAT AND EQUIPPED WITH A FRONT 60/40 SPLIT BENCH SEAT. THESE VEHICLES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 225, "CHILD RESTRAINT ANCHORAGE SYSTEMS." THE TOP TETHER ANCHOR FOR THE FRONT CENTER SEAT IS NOT ACCESSIBLE AND THE OWNER MANUAL DOES NOT INCLUDE INSTRUCTIONS REGARDING HOW TO USE THE TOP TETHER.
CONSEQUENCE:
BOTH NHTSA AND GM DISCOURAGE PLACEMENT OF A CHILD IN A FRONT SEAT. NEVERTHELESS, THERE ARE INDIVIDUAL CIRCUMSTANCES THAT MAY REQUIRE PLACEMENT OF A CHILD IN A RESTRAINT IN THE FRONT CENTER SEATING POSITION OF THIS VEHICLE THAT DOES NOT OFFER A REAR SEAT. LACK OF ACCESS TO THE TOP TETHER ANCHOR AND A LACK OF INSTRUCTIONS AS TO HOW TO USE IT, MAY RESULT IN IMPROPER INSTALLATION OF A CHILD RESTRAINT. IMPROPER INSTALLATION OF A CHILD RESTRAINT CAN RESULT IN A REDUCTION IN THE RESTRAINT'S PERFORMANCE IN THE EVENT OF A CRASH AND AN INCREASED RISK OF INJURY OR DEATH TO THE CHILD SEATED IN THE RESTRAINT.
REMEDY:
DEALERS WILL CUT A HOLE INTO THE BACK PANEL TRIM COVER TO ALLOW ACCESS TO THE TOP TETHER ANCHOR FOR THE FRONT CENTER SEAT POSITION AND WILL PROVIDE SUPPLEMENTAL INFORMATION AS TO USE IN THE OWNER'S MANUAL. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE FOR THIS CAMPAIGN. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438, GMC AT 1-866-996-9463, ISUZU AT 1-800-255-6727 OR VISIT GM'S WEBSITE AT WWW.GMOWNERCENTER.COM.
NOTES:
GM SAFETY RECALL NO. 10367 AND/OR 10407. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Receipt Date: JUL 29, 2009
NHTSA Campaign Number: 09V310000
Component(s): EXTERIOR LIGHTING
Details close
17 Associated Documents expand
SUMMARY:
GM IS RECALLING 185,903 MODEL YEAR 2004-2009 COLORADO, GMC MODEL YEAR 2009-2004 CANYON, MODEL YEAR 2006 I-280, I-350, MODEL YEAR 2007-2008 I-290, AND I-370, PASSENGER VEHICLES ORIGINALLY SOLD IN OR CURRENTLY REGISTERED IN THE STATES OF ALABAMA, ARIZONA, FLORIDA, GEORGIA, HAWAII, LOUISIANA, MISSISSIPPI, NEVADA, NEW MEXICO, PUERTO RICO, SOUTH CAROLINA, TEXAS, U.S. VIRGIN ISLANDS AND UTAH. SOME OF THESE VEHICLES HAVE A BRAKE LAMP SWITCH THAT MAY NOT WORK AS DESIGNED DUE TO CONTAMINATION IN THE SWITCH.
CONSEQUENCE:
THIS CONDITION COULD CAUSE THE SIMULTANEOUS LOSS OF ALL BRAKE LAMPS OR CAUSE ALL OF THE BRAKE LAMPS TO STAY ON CONTINUOUSLY. BOTH OF THESE CONDITIONS COULD FAIL TO WARN OTHERS OF THE DRIVER'S INTENTIONS AND COULD LEAD TO A VEHICLE CRASH.
REMEDY:
DEALERS WILL INSPECT AND REPLACE THE NECESSARY COMPONENTS AS SPECIFIED IN THE RECALL BULLETIN FREE OF CHARGE. GM ANTICIPATES THAT PARTS WILL BE AVAILABLE BY JUNE 2010. A SPECIAL COVERAGE FOR VEHICLES REGISTERED IN ALL OTHER STATES WILL BE IMPLEMENTED IN THE SAME TIME FRAME. IN THE INTERIM, OWNERS WHO EXPERIENCE THE FAILURE CAN OBTAIN A FREE REPAIR, HOWEVER THEY WILL BE REQUIRED TO RETURN WHEN THE NEW DESIGN PART BECOMES AVAILABLE. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438, GMC AT 1-866-996-9463, ISUZU AT 1-800-255-6727 OR AT WWW.GMOWNERCENTER.COM.
NOTES:
GM RECALL NO. 09049. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Receipt Date: MAY 06, 2009
NHTSA Campaign Number: 09V154000
Component(s): FUEL SYSTEM, GASOLINE
Details close
SUMMARY:
GM IS RECALLING 27,188 MY 2009 CADILLAC ESCALADE, ESCALADE HYBRID, ESCALADE ESV, AND ESCALADE EXT; CHEVROLET AVALANCHE, SUBURBAN, TAHOE, TAHOE HYBRID, AND COLORADO; AND GMC YUKON, YUKON HYBRID, YUKON XL, AND CANYON VEHICLES. THE FUEL SYSTEM CONTROL MODULES MAY HAVE A CONDITION IN WHICH AN ADHESIVE SEPARATION OF THE ROOM TEMPERATURE VULCANIZING (RTV) SEAL BETWEEN THE SEAL AND THE HOUSING MAY ALLOW WATER TO SEEP INTO THE MODULE.
CONSEQUENCE:
WATER IN THE MODULE COULD CAUSE A SHORT OR OPEN CIRCUIT, ILLUMINATION OF THE SERVICE ENGINE SOON LAMP, SETTING OF DIAGNOSTIC TROUBLE CODES OR THE ENGINE MAY BE HARD TO START, MAY NOT START OR MAY STALL INCREASING THE RISK OF A CRASH.
REMEDY:
DEALERS WILL INSTALL A NEW FUEL SYSTEM CONTROL MODULE FREE OF CHARGE. THE RECALL BEGAN ON MAY 18, 2009. OWNERS MAY CONTACT CADILLAC AT 1-866-982-2339, CHEVROLET AT 1-800-630-2438 AND GMC AT 1-866-996-9463 OR AT WWW.GMOWNERCENTER.COM.
NOTES:
GM RECALL NO. 08411. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Report Receipt Date: AUG 11, 2006
NHTSA Campaign Number: 06V307000
Component(s): WHEELS
Details close
5 Associated Documents expand
SUMMARY:
CERTAIN SPORT UTILITY VEHICLES AND TRUCKS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 110, "TIRE SELECTION AND RIMS." THESE VEHICLES HAVE AN INCOMPLETE TIRE RIM DESIGNATION ON THE CERTIFICATION/TIRE LABEL LOCATED ON THE DRIVER'S DOOR EDGE. IN ADDITION, THE LABEL MAY ALSO BE MISSING THE TIRE LOAD RATING ON THE LABEL. ALTHOUGH THIS INFORMATION IS NOT REQUIRED BY THE STANDARD, IF A TIRE OF A LESSER LOAD RATING IS INSTALLED, THE TIRE MAY NOT BE ABLE TO SUSTAIN THE LOADS ENCOUNTERED DURING USE.
CONSEQUENCE:
IF A CUSTOMER REPLACES A WHEEL AND ONLY RELIES ON THE RIM SIZE DESIGNATION THAT IS INDICATED ON THE LABEL, A WHEEL THAT IS OF A DIFFERENT RIM CONTOUR DESIGNATION MAY BE INSTALLED. IT MAY BE DIFFICULT OR IMPOSSIBLE TO MOUNT THE TIRE ON A WHEEL WITH THE WRONG CONTOUR. IF THE TIRE IS MOUNTED ON THE WHEEL WITH THE WRONG CONTOUR, THE WHEEL AND TIRE MAY NOT PERFORM AS INTENDED, WHICH COULD INCREASE THE RISK OF A CRASH.
REMEDY:
A LABEL THAT WILL CORRECT THE LABEL ORIGINALLY INSTALLED WILL BE MAILED TO CONSUMERS ALONG WITH INSTALLATION INSTRUCTIONS. THE CUSTOMER WILL HAVE THE OPTION FOR DEALERS TO INSTALL THE LABEL. THE RECALL BEGAON ON NOVEMBER 7, 2006. OWNERS SHOULD CONTACT CADILLAC AT 1-866-982-2239, CHEVROLET AT 1-800-630-2438, AND GMC TRUCKS AT 1-866-996-9463.
NOTES:
GM RECALL NO. 06079. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Report Receipt Date: APR 27, 2006
NHTSA Campaign Number: 06V139000
Details close
13 Associated Documents expand
SUMMARY:
CERTAIN PICKUP TRUCKS MAY EXPERIENCE THE PERMANENT LOSS OF BRAKE LAMP FUNCTION OR BRAKE LAMPS THAT ARE ILLUMINATED AT ALL TIMES. THE CENTER HIGH-MOUNTED STOP LAMP (CHMSL) IS AFFECTED IN BOTH INSTANCES. ALSO, IF EQUIPPED, THE CRUISE CONTROL WILL BECOME INOPERATIVE. ANY TRAILER BRAKE LAMPS WHICH ARE CONNECTED TO THE VEHICLE'S BRAKE LAMP WIRING WILL MIMIC THE VEHICLE'S BRAKE LAMPS WHEN EITHER CONDITION OCCURS.
CONSEQUENCE:
A FOLLOWING DRIVER MAY NOT KNOW WHEN THE BRAKES HAVE BEEN APPLIED, AND A REAR-END CRASH COULD OCCUR WITHOUT PRIOR WARNING.
REMEDY:
DEALERS WILL REPLACE THE BRAKE LAMP SWITCH ASSEMBLY. THE RECALL BEGAN ON DECEMBER 5, 2006. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438; GMC AT 1-866-996-9463 OR ISUZU AT 1-800-255-6727.
NOTES:
GM RECALL NO. 06030. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Report Receipt Date: DEC 07, 2005
NHTSA Campaign Number: 05V552000
Component(s): EQUIPMENT - wheel Information, Misprint
Details close
9 Associated Documents expand
SUMMARY:
CERTAIN TRUCKS AND SPORT UTILITY VEHICLES FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 110, "TIRE SELECTION AND RIMS." THESE VEHICLES WERE SHIPPED WITH TIRE AND LOADING INFORMATION LABELS LISTING AN INACCCURATE VEHICLE CAPACITY WEIGHT.
CONSEQUENCE:
A MISPRINTED LABEL COULD LEAD TO IMPROPER VEHICLE LOADING SPECIFICATIONS OR TIRE INFLATION WHICH COULD RESULT IN A TIRE FAILURE, INCREASING THE RISK OF A CRASH.
REMEDY:
OWNERS WILL BE PROVIDED WITH CORRECTED LABELS AND INSTALLATION INSTRUCTIONS. AT THE CUSTOMER'S OPTION, A DEALER CAN INSTALL THE LABEL FOR THEM. THE RECALL BEGAN ON MARCH 31, 2006. OWNERS MAY CONTACT BUICK AT 1-866-608-8080, CADILLAC AT 1-866-982-2339, CHEVROLET AT 1-800-630-2438, GMC AT 1-866-996-9463, HUMMER AT 1-800-732-5493, PONTIAC AT 1-800-620-7668, SATURN AT 1-800-972-8876, OR ISUZU AT 1-800-255-6727.
NOTES:
GM RECALL NO. 05109. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
More To Follow AS REQUIRED
Discussion Starter #2
Update complete. I went through all model year 2004-2012
I shall tackle the 2015 next
Discussion Starter #4
No problem, just trying to pass on the good information in a centralized location
Several of those recalls I had never heard of
Discussion Starter #6
Texas Yoda!!!!
Discussion Starter #9
awesome, may want to add this to the Main post, thanks man!
Just did that, thank you for the recommendation Ed.......your already back in the groove of things @edvocho
This probably belongs in the Technical Area. Perhaps we could expand the "Service Bulletins" section to include Recalls. Rename it to "Service Bulletins and Recalls"?
I'm a team player @rshadd if you think there is a better way to combine and locate it all.....lets do it.
I'm "That Guy"
It shows 0 recalls for my truck using that search tool. I didn't know GM could make a vehicle without having a recall on it :shrug:
1 - 10 of 10 Posts
