1 - 6 of 6 Posts
Hello, I have an I-5 with 4L60E with 85K miles on the odometer.
I was removing the battery a while back and felt like I got a mild shock from wires that should have been grounds. I tested the battery while in the truck with a voltimeter and saw that the battery is not getting anything from the alternator. It went from 12v to 10v and dropping as I tested.
I have since cleaned the ground and the connections. I checked the wires on the alternator. I cleaned those as well.
The truck has a battery message that comes up on the dash/information center.
I have not used a code reader. I need to buy one.
I have seen alternator rebuild kits and electronic regulator bits online.
I have seen rebuilt alternatives as well.
Any recommendations?
The battery is still not taking charge so the truck is not going anywhere.
Discussion Starter · #4 ·
I replaced the belt, adjuster, and idler as well as the Alternator and solved that problem just in time for a catastrophic transmission failure.
So now I get to replace and rebuild the transmission.
Just buy an alternator and swap it out.
Internet Troll
Sounds like my world.....
Replacing the brickmould on a door at the house ended with me replacing an entry door and 30 Sq feet of siding over the weekend. Termite guys coming in the morning....
Happens that way sometime. Simple, easy repair turns into a black hole that just sucks in all the money.
1 - 6 of 6 Posts
