Hello, sorry if this is in the wrong place...
The last couple months my cabin fan has been working intermittently, I have checked the resistor and connections/cable harness and they look fine as best as I can tell. The fuse looks fine as well.
All 4 fan speeds stop working sometimes, doesn't seem dependent on temperature, and it doesn't seem to matter if its been sitting awhile or not.
I think its the switch, I took the entire fan-controller module out and inspected everything for burnt it loose connections but it all looked fine as well.
Additionally when my fan speed dial isn't working, it doesn't turn the orange AC light off like it normally does. When it works the AC light and compressor will turn off when the fan is set to "0"
Any other recommendations before I drop +100 on a new fan controller module to replace the one switch?
I have a 2004 Colorado, regular cab, 3.5l 5cyl-auto
