Thanks haha
Thanks hahaCrazy build, the truck looks awesome, engine bay honestly looks factory!!
Definitely sending this to dad, he has a ZL1 and likes the Colorados!
Thanks! It is far from finished though! The next stage will be custom IFS front suspension and convert the rear axle to full floating and a custom front IFS differentialAwesome build! Very nice finished project with nice attention to detail. Congrats on a great project!
*cough* this *cough*Thanks! It is far from finished though! The next stage will be custom IFS front suspension and convert the rear axle to full floating and a custom front IFS differential
I would love that, but it's more than I want to spend. with the stub shafts it's like $2400. Plus then I would have to move my control arm mounting points in board to work with the width of that housing. I'm thinking more along the lines of what they did here with a custom Dana 44 IFS diff.*cough* this *cough*
All the "service 4wd" errors went away when I unplugged the 4wd control module! I'm pretty sure the BCM just thinks it is a 2wd now haha.Always felt it was kinda weird mating old tech to new tech, but I think the 205 gets a pass. Just can't beat that thing. Did you flash a new file into the BCM? Pretty sure it sets a U code when the TCCM drops off the bus... Either you deal with the 'service 4wd' coming up constantly in the cluster or you put different software in the BCM lol.
Absolutely. Lots of roomWill a 6L80E/90E fit in a stock Colly
trans tunnel ?
I thought the PCM was a 2010 v8 Colorado E67 PCM but turns out it is a 2010 3.7 Colorado PCM that I flashed to the v8 OS and it somehow worked. I think the serial number in the PCM is corrupted now but it is working. BCM is stock 2005 Colorado. All that really needs done is to wire up the T43 TCM to the E67. I'm guessing similar to how the T42 is wired up, but the wires go to the Transmission since the TCM is in the valvebody.what PCM./BCM did you use ? what OS did you use
to get the 6L80E to work ?
