can you show the wiring patch for
The T43 TCM to the E67 ? Does the
V8 OS have the settings for the 6L80E ?
or does it run off the T43 only.
I don't really have any pictures of just the wiring for the 6L80e. It should just use the wires that normally go to the T42, but instead they get routed to the T43. Once the 6l80e is wired up, you just do a read of the PCM and TCM and it shows up as the E67 and T43 seperately. All the trans settings are in the T43. You just have to make sure the years of the PCM and TCM Operating systems are compatible with each other.can you show the wiring patch for
Thank you! The front e-locker is in. Everything installed just fine. I still need to wire it up. I'm trying to decide where to put the switch. We got a little tease of snow a couple weeks ago, but now we have nothing. I havnt gotten to go test it yetLooks great. Nice stance.
This has become my favorite build thread by far. You have a truly one of a kind drivetrain for a Colorado.
BTW: How did the front e-locker work out?
currently no, but I don't think that's the fan's fault. It seems to run at about 210 degrees even going down the highway. I think I have too much stuff blocking airflow. I have the Heat exchanger out front, as well as the transmission cooler, power steering cooler, and the AC condenser. And I think think it has the stock radiator with 225K miles on it. I'm looking at the griffin radiator with a 2.6" thick core.Hi, does your Taurus e-fan keep your eng cool enough ?
Thanks sir!I just followed you on IG last night.
Impressive build and your fabrication/ing skills are stellar
pm sentYETTI,I have a custom all alum 2 core H3 rad a tried to use
but couldn't get to fit right. almost but not quite fit my e-fans.
If you would like to try it i can ship it to you. if it works out we can work
out a deal, it cost me $450.00, I used it for 2 weeks.
It was made by CRS rads.
About 4 feet in some spots if you were to dig down to dirt.That is a LOT of snow
