Everything they said is true. If you buy the 08 you'll have a very nice all-aluminum door stop.
Everything they said is true. If you buy the 08 you'll have a very nice all-aluminum door stop.I need a 2.9 for my colorado and I found one out of an 08 with low miles, the yard that has it telling me that its different from 07. They said the intake, cam actuator, crank sensor, and i believe cam sensor are different. Can anyone shed some light on whether on not the 08 engine will work in my 07 truck?
I believe the reluctor wheel is also different, yes.Well since the head is interchangeable, why can't all of that just be swapped? Or does the 08 have a different reluctant wheel on the crank?
