1 - 11 of 11 Posts
It looks to me like this is the same filter as 00-08 fullsize trucks. K&N has the dimensions on their site and mine measured perfectly. Stay tuned for confirmation once I find one for cheap :D
Discussion Starter · #2 ·
update: no such luck. I stopped at the auto parts store and they let me try one...it was about 1/2 inch too wide for the box and I couldn't get it to sit properly. back to the waiting game I guess.
Bagged Bomber
not possible they are completely different. Come mice chewed mine up and i went to get a new one but no dice. 07 is a cylinder 08 is flat
not if you get the complete intake system.
Not perfectly... Try it out and then revise that statement. :true:
:355:
ive heard it fits perfectly. i cant try it myself as i have an 07.
such as? as far as i know the only changes from 07 to 08 is the panel type filter instead of a cylinder type filter and having separate ECM and TCMs instead of a PCM.
airbox mounting points maybe?
For starters the air box design changed all together. Yes, the mounting points are different, so the 2007 kit is not a plug and play for installing it. There appears to be some minor changes in the MAF sensor/housing which also complicates the plug and play method if you do not have the HP Tuner available.
i didnt realize the maf sensor mounting. i'll take a look at work when i get the chance.
1 - 11 of 11 Posts
