1 - 5 of 5 Posts
I have a couple Evap codes and a cam shaft and crank shaft sensor codes aswell as egr I believe but I just recently replaced that cam/crank sensors aswell as the camshaft actuator solenoid
You say it happens sometimes. Is that a cold, hot or both for starting?
Only does it when it’s hot like if I start it up in the morning it starts fine but say if I go for a quick little drive then come back & shortly after I go to start it again it will do that. But it’s not all the time.
1 - 5 of 5 Posts
