2009 gmc canyon v8 5.3
290 Views 13 Replies 4 Participants Last post by  Ballance08
I’ve recently purchased a 2009 canyon 5.3, the motor is locked up. I’m wanting to just replace the motor. What other LS engine would go in the canyon with the least amount of changes.
1 - 14 of 14 Posts
Welcome to 355Nation. The 09 V8 is the LH8 without VVT. The 10-12 V8 is the LH9 with VVT. I would stick with the LH8 because it does not have any kind of VVT, AFM, DFM, or DOD. Less parts to fail and will be more reliable.
Any remanufacture you recommend?
I have never had to replace an engine so I can't recommend anyone. Is rebuilding yours out of question? Hop it up a little bit while in there.
Not entirely out of question, haven’t opened it up to see the damage yet
That way you get exactly what you want.
You've got to remove that motor anyway, so why not start with that and assessing the damage? It's probably best to have a machine shop rebuild it. Plus you end up with a minty fresh motor setup how you like.
As others said, the LH8 is the motor you have and would want to find if replacing. It's an aluminum block Gen IV LS (58 tooth reluctor), found in H3's too but good luck finding one. If you did swap motors you would need to keep the low oil pan, the exhaust manifolds, and all that stuff that's on your truck right now so do not get rid of it.
With enough work, you could put any LS in there, but it's really not worth the hassle and cost to make it function as designed. I'd strongly suggest taking it to a reputable engine shop.
  • Like
Reactions: 1
Thanks for all the info man. Do you know about how much it would cost all together to have the engine rebuilt? I have about $3500 to work with.
Could I install a LY5 in it?
That's a loaded question. If you pull the motor yourself and take it to a shop, $3500 may be in the ball park but it just entirely depends on what damage it has. May need new pistons, resleeved, head work, etc.
No matter what you need to pull that motor. Get that far as a first step, then pull it apart and price out rebuilds vs a different motor.
I'm not an expert on the differences between engine variants. You could get a different gen 4 motor (iron block like the LY5) for probably $2,000 at the junkyard, throw it in the truck and make it work. You'd have to swap the accessories, oil pan, probably some sensors, the intake, etc over to the new engine. There's more than likely going to be differences you don't expect. Devil is in the details.
At that point, you'd have spent easily $2500 and lots of hard work swapping in an engine that's high mileage, heavier, probably leaks oil, and just generally isn't a spring chicken when you could've rebuilt the factory aluminum block for not a whole lot more.
I don't want to be annoying, that's just what I would do. I spent a lot of time plopping an LS in my 2004 figuring out little details. You've been blessed with a factory V8 truck that just needs a rebuild.
Welcome 2 the nation
Update motor is gone(buster block), what engine with 58x reluctor and no dod and vvt will work?
Another LH8. That motor was also put in the full size GM trucks. What years exactly I don't know. My understanding was that GM de-tuned the version that went into the Canyon/Colorado.
Does anyone know what year transmission i have to use? I know it’s a 4l60e, but I not sure if it has to be a certain year.
1 - 14 of 14 Posts
