1 - 5 of 5 Posts
Did both of these light problems begin at the same time? The Aux Power Outlets each have a separate fuse in the fuse box in the engine compartment. The Rear Turn Signals have a separate fuse, also located in the same fuse box. Look on the inside of the fuse box cover for a diagram of fuse locations. Do the rear hazard bulbs flash? They are on the same fuse as the turn signals.
If the fuses are all good, post back. You may have a ground problem.
You have a ground problem. Read a how-to on fixing the ground locations on the front fenders on both sides. One by the breather housing and the other by the ABS plumbing. I feel quite confident that you'll find that fixes your problems.
1 - 5 of 5 Posts
