1 - 2 of 2 Posts
my 2010 Colorado I4 is running rough when first started and seems to be sounding louder. I took it to Autozone. They said P0017 code. I pulled the Camshaft sensor and the screens looked fine. I think its under warranty. 63,500 miles 4 years old. its sceduled to go to dealer next week. Any thought what it might be?:ugh:
Google says:
Causes may include: Timing chain stretched, or timing belt skipped a tooth due to wear
Misalignment of timing belt/chain Tone ring on crankshaft slipped/broken
Tone ring on camshaft slipped/broken
Bad crank sensor
Bad cam sensor
Damaged wiring to crank/cam sensor
Timing belt/chain tensioner damaged
An improperly torqued crankshaft balancer
A mis-built or mis-timed engine A loose or missing crankshaft balancer bolt
The CMP actuator solenoid stuck open
The CMP actuator stuck in a position other than 0 degrees
Read more at: P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
Copyright © OBD-Codes.com
Good luck!
1 - 2 of 2 Posts
