Friends don't let friends drive fords lol love your colorado I'd keep it,
^^ I like your thought processThe question is -- do you want something that is 'popular' & off the shelf? Or do you want something unique? If unique, I would stick with the Colorado.
I'd have to disagree. Ford reliability has been outstanding the last 10 years, especially compared to Toyota, GM, and Dodge. And the comment about the weak frames is also inaccurate. That frame is rated to tow around 11 000lbs and it's the stiffest half-ton frame on the road. The fools that bent their frames hit the equivalent of a curb going 90+. The folks with them that didn't wreck their trucks were pretty clear about who was at fault here and it wasn't the truck. Anyhow, imagine what would happen to a canyon/rado if someone cranked something like a curb going 90... it'd likely explode.I wouldn't. Ford has been horribly unreliable and those things are filled with computers and have weak frames. With the money you have in the Colorado you will lose your ass on resale on top of now spending more on a new truck that really isn't any better.
The tow capacity is 6,000 lbs to start. Look at the shackle mounts and how the frames warp after a few runs through a twist ditch, I'm not just referring to the common article. Ford doesn't use the high quality steel or even close to the same thickness, the raptor was lucky they even decide to box the frame because up until recently everything was c-channel. They have 3/4's of the advertised travel in the droop and the opposite direction is the same as 90% of the trucks on the road. Ford is also riddled with transmsision issues, they rot faster than any vehicle here in the northeast in the wheel wells, and look up the issues revolving the ecoboost engines. Ford has more problems than most.I'd have to disagree. Ford reliability has been outstanding the last 10 years, especially compared to Toyota, GM, and Dodge. And the comment about the weak frames is also inaccurate. That frame is rated to tow around 11 000lbs and it's the stiffest half-ton frame on the road. The fools that bent their frames hit the equivalent of a curb going 90+. The folks with them that didn't wreck their trucks were pretty clear about who was at fault here and it wasn't the truck. Anyhow, imagine what would happen to a canyon/rado if someone cranked something like a curb going 90... it'd likely explode.
finally someone mentioned the weak frames. Ford is always known for their weak frames, and if you use this truck "as its designed" it will bend/tweak. You can build the suspension on our trucks (long travel) to do better off road than these raptor terds.I wouldn't. Ford has been horribly unreliable and those things are filled with computers and have weak frames. With the money you have in the Colorado you will lose your ass on resale on top of now spending more on a new truck that really isn't any better.
"400 HP"I'd have to disagree. Ford reliability has been outstanding the last 10 years, especially compared to Toyota, GM, and Dodge. And the comment about the weak frames is also inaccurate. That frame is rated to tow around 11 000lbs and it's the stiffest half-ton frame on the road. The fools that bent their frames hit the equivalent of a curb going 90+. The folks with them that didn't wreck their trucks were pretty clear about who was at fault here and it wasn't the truck. Anyhow, imagine what would happen to a canyon/rado if someone cranked something like a curb going 90... it'd likely explode.
But back to the comparison, there is a huge difference in build quality between a full-size and a midsize truck. All of the manufacturers put all their energy into their flagship models, which has never been their small trucks. With how similar the prices are between full and mid-size trucks I don't think I would go with a mid-size again. Not to mention that the mileage these days is pretty close.
There is no doubt you'll burn more fuel with the Raptor, but it has it's upsides. You get 400+ HP, long travel suspension, and 35'' tires in a truck with an exceptionally low center of gravity.
Exactly right, GM has been one of the few manufactures with fully boxed frames for a long time. The fact that a GM vehicle has gotten better mileage all this time puts Ford to shame, since they are using the "weight reduction" approach to better MPGs i.e. c channel frames and aluminum bodies.The tow capacity is 6,000 lbs to start. Look at the shackle mounts and how the frames warp after a few runs through a twist ditch, I'm not just referring to the common article. Ford doesn't use the high quality steel or even close to the same thickness, the raptor was lucky they even decide to box the frame because up until recently everything was c-channel. They have 3/4's of the advertised travel in the droop and the opposite direction is the same as 90% of the trucks on the road. Ford is also riddled with transmsision issues, they rot faster than any vehicle here in the northeast in the wheel wells, and look up the issues revolving the ecoboost engines. Ford has more problems than most.
The colorado in stock form won't perform as well offroad but it's not made for that and typically costs 1/3rd the price except the v8 trucks which were a little closer to half the cost. Your maintenance is also a hell of a lot cheaper.
