TRIFECTA presents: Chevrolet Colorado / GMC Canyon MY2015+ Powertrain Calibration Reprogramming
TRIFECTA presents a complete powertrain power delivery profile calibration for the MY2015+ Chevrolet Colorado / GMC Canyon LFX engine and corresponding 6L50 automatic transmission reprogramming. The TRIFECTA Performance Chevrolet Colorado LFX 3.6 and GMC Canyon LFX 3.6 MY2015+ powertrain calibration is an easy to install software performance calibration with an included flash loader device that will yield gains of +31 ft-lbs and +27 WHP (Peak gains of +26 ft-lbs and +21 WHP) to a completely stock GMC Canyon LFX 3.6 MY2015.
View this product in our Store!
2015+ Chevrolet Colorado - 3.6L
2015+ GMC Canyon - 3.6L
The TRIFECTA Elite Powertrain Calibration with Individualization (Custom Profiling) for the MY2015+ Chevrolet Colorado / GMC Canyon LFX includes calibration individualization, remote diagnostics, and comprehensive aftermarket hardware software integration support. (includes a TRIFECTA flash loader)
Specifications of the TRIFECTA Performance Chevrolet Colorado MY2015+ and GMC Canyon MY2015+ 3.6 LFX ECM software reprogramming:
-Gains of +31 ft-lbs and +27 WHP under the curve (and +26 ft-lbs and +21 WHP peak on 91 octane)
-Powertrain calibration has been tested and validated for various environments, such as cold/heat, elevation, and variations in fuel quality
-Power feels linear and immediately responsive (improved drivability and throttle attentiveness)
-Retains all GM OE diagnostics and ECM functionality
-Retains all OE error code reporting and functionality
-Emissions readiness checks are present; emissions compliant
-Maintains functionality of ABS and TC systems
-Knock detection mechanisms and OE engine knock detection sensitivity is retained
-The TRIFECTA flash loader and Transparency featureset does not increment the ECM write counter or increment entries in the flash history
-Return to stock functionality included with flash loader
Specifications of the TRIFECTA Performance MY2015+ Chevrolet Colorado / GMC Canyon 6L50 6-Speed automatic transmission TCM calibration software reprogramming:
-Supplementary 6L50 transmission TCM reprogramming compliments the ECM reprogramming and completes the TRIFECTA Powertrain Calibration: designed to work in unison with the ECM reprogramming for optimized performance
-Improved shift times in adverse shift patterns
-Improved shift logic (improved drivability)
-Does not shorten transmission life or increase cooling requirements
-Retains all OE diagnostics and TCM functionality
-Improved fuel economy with improvements made to torque converter slip profiles
Supplementary Featureset of the TRIFECTA Performance MY2015+ Chevrolet Colorado / GMC Canyon powertrain calibration software reprogramming:
-TRIFECTA Interactive Driver Selectable Vehicle Mode (Select-a-Tune MKII); NEW! Dedicated ECO Mode: Toggle between Tour and ECO mode via the Cruise Control arm states
-TRIFECTA ECO Mode: Up to 2.8 MPG improvement by dedicated TRIFECTA ECO mode prioritizing fuel economy in engine calibration profile and transmission shift strategy
-Alternative Driver Profiles layout included with individualized calibration (OPTIONAL): Allows on the fly Driver Profile switching back to OE settings/profile (Select-a-Tune MKI can allows the driver to select between the calibrated and stock drive experience and power output)
-TRIFECTA Octane Adaptive MKII featureset will bias for lower octane fuels (multi dimensional airflow knock and timing decay tables, not just high/low)
-Improved fuel economy while towing with alternative TOW/HAUL mode
Installation Notes:
-Estimated installation time of ~20 minutes
-Premium fuel is recommended, but not required
3.6 LFX dyno graph (on 91 octane pump gas) (this vehicle is a 2015 GMC Canyon CrewCab 2LT with a 3.6 LFX engine) - stock wheels/tires
Additional information and availability:
-This powertrain calibration includes a TRIFECTA powertrain calibration file specific to your vehicle and includes a flash loader device
-Includes free upgraded intake (when available)
-Powertrain calibrations currently exist for North American vehicles only, with more regions to follow
Installation Notes:
