This is mainly to get info posted about what's available for the 2015...
2015 GM COLORADO/CANYON 2WD/4WD 1.25" LEVELING KIT Zone Offroad Products
Zone C1121
Owners of the all new 2015 Chevy Colorado and GMC Canyon 4X4s can level up their trucks quickly and easily.
The strut spacers are laser cut from steel and e-coated for long lasting corrosion protection. This kit is completely bolt on and does not require disassembly of the factory strut. This is the maximum amount of "top spacer" these trucks can have and still properly work within the limits of the factory suspension.
The new trucks set about 1.5" tail-high from the factory so adding this kit levels them out nicely and creates enough space to go up to a 265X75R17 tire using a 17" wheel with 5.75" backside.
Zone strut spacers are a proven inexpensive way to level your truck while still maintaining the factory ride quality.
Features:
◾Fast and Easy Install
◾Solid One-Piece Design
◾No Strut Compressor Required and No Disassembly of the Strut
◾Does not Change Your Factory Ride
◾Easy to Follow Instructions Included
◾Great Warranty
◾265/65R17 Tire on factory 17x8 wheel w/5.75" backspacing - this includes any equivalent spec'd larger diameter (18", 20", etc) wheel/tire combo.
Quick Specs
◾Front Lift Height: 1.25″
◾Front Lift Method: Top Strut Spacer
◾Wheel Size: 17
◾Back Spacing: 5.75″
◾Max Tire Size: 265/65R17
http://zoneoffroad.com/zone-offroad-products-1in-suspension-leveling-kit-colorado/c1121
Zone C1121
Features:
◾Great Warranty
Quick Specs
◾Wheel Size: 17
