Zone has combined the two lift kits it offers for the 2015s in one package. This kit saves a little money if you plan to add both to your truck.
Zone Offroad 2.75" Combo Lift Kit for 2015 Colorado/Canyon (4wd/2WD):
Our 2.75" Combo kit includes our 1.25" front leveling kit (C1121) and 1.5" body lift (C9157) for a complete lifted/leveled look and room for 285/70R17 tires on the stock wheels (5.75" BS). This kit is complete, including all the parts necessary for the leveling kit and body lift install, as well as step by step, detailed installations instructions. All while maintaining the factory ride quality and handling.
Give your new Colorado/Canyon the tough look it should have from the factory, with a very small investment of time and your hard earned money!
ADDITIONAL COMPONENT INFO:
1.25" Leveling Kit (C1121) Description: Zone Offroad 1.25" leveling kit - The strut spacers are laser cut from steel and e-coated for long lasting corrosion protection. This kit is completely bolt on and does not require disassembly of the factory strut. This is the maximum amount of "top spacer" these trucks can have and still properly work within the limits of the factory suspension. These new trucks set about 1.5" tail-high from the factory so adding this kit levels them out nicely and creates enough space to go up 1 size tire.
1.5" Body Lift (C9157) Description: Zone Offroad 1.5" Body Lift - This is a complete kit, including all body and bed mounting spacers with hardware, as well as front and rear bumper relocation brackets to maintain the factory body lines. We utilzie our crush proof body blocks and class 10.9 body and bed mounting hardware, and include detailed, step by step instructions for an easy installation.
Featured Technology & Benefits
◾2.75" Combo kit - Includes: 1.25" Leveling Kit (C1121) & 1.5" Body Lift (C9157)
◾Complete kit
◾Includes detailed, step by step installation instructions
◾Designed for a lifted/leveled look and room for 285/70R17 tires on the stock wheels (5.75" BS)
◾Maintains factory ride quality
◾Limited Lifetime Warranty
◾ADDITIONAL COMPONENT INFO:
◾1.25" Leveling Kit (C1121) Features:
◾Laser Cut Steel
◾E-Coated For Corrosion Protection
◾Completely Bolt-On - No strut disassembly required
◾1.5" Body Lift (C9157) Features:
◾Complete 1.5" body lift kit
◾Includes front and rear bumper relocation brackets
◾Grade 10.9 body and bed mounting bolts
◾Quicker and easier install than larger body lifts
◾No effect on towing ability
Quick Specs
◾Front Lift Height: 2 3/4″
◾Front Lift Method: Strut Spacers & Body Lift
◾Rear Lift Height: 1 1/2″
◾Rear Lift Method: Indestructible Body Blocks
◾Install Time Hrs: 3-5
◾Difficulty Level 1-5: 2
◾Wheel Size: Stock
◾Back Spacing: Stock
◾Max Tire Size: 285/70R17
◾Wheel Size: 17
◾Back Spacing: 5.75
http://zoneoffroad.com/zone-offroad...sion-lift-kit-chevy-gmc-colorado-canyon/c1257
