1 - 4 of 4 Posts
Will 2015 canyon/Colorado all terrain rims fit on older Silverado - are the bolt patterns the same? If not how bout on older Colorado?
Re: 2015 Colorado/canyon tire question
New Colorado has a 6x120 mm bolt pattern... so no it will not fit. Older colorado 2004-2012 have a 6x139.7 mm bolt pattern... so yes they will fit a 6 lug silverado but the center bore of the colorado rims is larger so you may want to you hub centric rings with them
You may want to change the title of the thread from tire to rim/wheel.
So just so im clear the 2015 canyon rims will not fit a Silverado no way no how?
1 - 4 of 4 Posts
