1 - 20 of 286 Posts
Member's Technical crew
Well, got her done! YEAH!!! She is now able to be driven! Man am I happy! I have some bugs to work out...and MAY have to even pull the trans back down :ugh: BUT she is drivable for now. That's what is important! For those of you who have not been keeping up, I hydrolocked a 3.5 in my 04 truck. So i swapped in a 07 3.7!!
First question everyone wants to know...what is the difference..? It's AWESOME! I had my 3.5 tuned, had the cat gutted, and was running mobil 1 fluid. There is NO comparison! The 3.7 is just awesome! From the bottom end she pulls harder, from teh top end she pulls harder, and you had better hold on when she shifts! LOL I KNOW I am gonna get even more from her when I do eventually do the exhaust. And of course get PCM's for less to retune her...But for now, I am LOVING the extra power.
Now, as for the tips YOU should know and the whole reason I made this new thread...
3.5 to 3.7 swap...
1) MUST use 3.7 from 07 model truck NO OTHER WILL WORK.
2) MUST swap fuel rails from the 3.5 TO the 3.7. Why? Because the 3.5 use's a return style fuel rail, the 3.7 use's a returnless fuel rail. I also swapped out the fuel injectors sense they were newer.
3) MUST swap over the EGR block off plate. The newer engine use's a egr, our older engine's did NOT.
4) MUST use your older 3.5 harness! The newer one has wire's ran for the egr valve, as well as some connector's I DID NOT see on there for my engine. MAYBE you could get away with useing it, But I highly doubt it.
5) IF you have a factory Block heater....YOU WILL NOT have it anymore..lol. The new 07 engine does NOT have a hook up for it. So be prepared for that.
6) There Are TWO O2 sensor's on the 3.7 mani...the 3.5 only has 1!!! SO, what do you do? lol I hooked up teh rear o2 sensor from the back of teh truck like it was stock. then i hooked up the FIRST o2 sensor closer to the engine...it works great. Then i just left the last o2 sensor just in case, and tied up the wire. But this is just another of those things I could not find anywhere on here..
7) The 3.5 ECM will run the 3.7 just fine. No need to swap it for the 3.7 ecm. Well, at least for me that is.
Now, some install tips...
IF the engine you buy has been setting for any lenght of time..it WILL knock upon start up unless you prime the oil pump. My engine had a ticking from the valve's for a good 30 minutes that would start and stop..now it run's baby butt smooth. Well, except for my issues that is.
IF you decide to do this, You may as well pull the trans with it!!! The trans is a WHOLE lot easier to get to when its out of teh truck. And you CAN pull them bth at the same time WITHOUT fear. It will come up and out of teh engine bay in one piece. You DO have to remove the rad...but sure you would anyway.
Once you get the trans back together and you need to reinstall the 3 bolts that mount the fly wheel to the Torque Converter, you will need to remove the little round disk by the dust guard. It is a view access point for you to line everything up! You simply look up in there, use a screw driver to turn it till one of teh 3 mounts are straight down, then turn the engine over till the hole in the flywheel lines up with the hole in the torque coverter, and install yoru first bolt! Then of course when you turn the engine over using the front mounted crank bolt, the flywheel and TQ will already be aligned for the other 2 bolts!
And last DO NOT remove the nuts that hold the trans cooler lines!!!!! IF you do you will be in for a long long day! If you look hard, you will see a retaining pin. Pull that out with a screwdriver and the line's pop right out! IF you are just now reading this AFTER you already undid them and now thinking oh shit...Well, here's how to can save face and get them bolted back in. Since of course you know that when you try to screw them in it simply pushe's back in right? LOL Well, get one of yoru wife's bobby pins. Bend it as to have a small hook on one end. Cut off the little bund on the end so it will "BITE" into the side of the cooler. Now, insert the bobby pin hook threw the nut you took out. Push it into the hole and try to hook it into the cooler. When you do get it to bite then slide the nut over it and slowly and barely screw it into the cooler. If you do it right, you will be rewarded with the nut getting a bit tighter until finally she stops. Then thank god your done with that one and start on the last one!
USE a leveler...it will make moving the engine and tilting it so much easier...
Have a buttload of kitty litter on hand to soak up all the oil, and trans fluid you lose.
The fan comes off the the LEFT! If you turn the screw right...you will be there ALL day. Turn LEFT! WHILE the damn belt is on! IT WILL make it so much easier!
IF you want to know, or need to ask a question you can always PM me. I am almost always on here...and of course get emails of PM's too...if i CAN help, I will. Good luck.
Re: Engine swap COMPLETE!!!
good to hear u got it running bro :thumbup:
NW Surfrider
Nice job man.
Thanks guys. Not as much a write up as a thread to kinda make damn sure EVERYTHING you need to know on doing this swap is in ONE thread ya know? When I was looking I found one thing here...one thing there..and a couple things that were NO where to be found. So...figured why not.
Spoolin Jr. Survivor
please have someone tune it in person rather than mail order tune because doing an engine swap creates a plethora of potential hazards with a mail order tune since they can't see where your fuel trims need to be with that specific engine. Congrats on the swap! :thumbup:
Discussion Starter #8
Yeah man, i live right next to PCM's man. The guys over there are pretty good guys. And yeah, there's only so much of a tune you can do over the mail. I just ride over there and have him ride with me..doing that makes ALL the difference. He spent over an hour in my truck last time..Thanks for the grats!
Discussion Starter #9
oh...I haz HUGE grin!!!
Glad she's rolling again!
glad you like the new engine man!
did you get any pics of the swap process
btw i have a question...did you get the 3.7 with accesories and all or the
accesories from the 3.5 bolt up directly to the 3.7 engine (alt,power steering, a/c etc.)
Discussion Starter #18
Awesome. My swap will be done this week.
Tellin ya man, you WILL LOVE it! I thought the 3.5 had decent power...no, it did NOT. To me, I will never long for a ls swap now..no need to! I don't need that kinda power. Now, this 3.7..it is a great upgrade is is almost a plug n play.
Discussion Starter #20
Good question. EVERY accesorie WILL bolt right up to the 3.7 from the 3.5!!! Intake, alt, power steering, you name it! The ONLY thing I did not try to bolt up...was the Exhaust Mani. Since the 3.7 is larger I did not feel the need to swap n a smaller mani.
Now, I only got the starter and exhaust mani with my engine. Well, the intake too..but as for teh other acc. No..I just swapped them from the 3.5.
1 - 20 of 286 Posts
