look at the 09+ brake swap should help you out
the only thing is. i already know how to change the hubs and pull that off what im needing to know is about the spacers on the lower control arm and how exactly do i take the ball joints out and back on. im thinking ill have to take it to a parts store and have them pressed on and off??look at the 09+ brake swap should help you out
thanks for the info! and ridinbaseline thanks cause that way when i get those spindles from you ill know how to do them! Thanks!:thumbup::yup:3 Spindle System w/ Rear Performance Shocks - 2004-08 GM Colorado/Canyon 2WD
Check the right side of this page...install instructs pdf
