35's on 16" rims after 9.5" lift?
1659 Views 7 Replies 6 Participants Last post by  Inferno_Beast
Hello I currently have an Isuzu I-350 Crew Cab 4x4 with a 2.5" leveling kit running 30" tires on 16" rims. I am about to get a 4" Tuff Country lift and 3" PA body lift to add on. Would 35's on 16" rims be a bad idea to do or what? I know I'd have to re-gear and stuff but what other issues would there be afterwards?
1 - 8 of 8 Posts
Might have to do some trimming, and / or get some wheel spacers, but it can be done.
Once you re-gear, truck should drive ok. The bigger tires will put more stress on your drivetrain. The CV axles and front drive shaft will be more prone to failure. Brakes will stop a little slower. Big tires could put more stress on the steering rack as well in some off road situations.
Won't the 4" tuff country lift eliminate the leveling kit thus only giving you 7" of lift?
Sent from AutoGuide.com App
The subframe lift kit gives 4" lift over stock. You can still crank the torsion bars (aka "leveling kit") above the stock adjustment. You might not get quite the 2.5" you had before, but close to it.
:yeahthat: If you crank on top of the subframe lift what your CV angles.2.5" of crank will put them at a steep shot to the knuckle.Plus you'll feel every pebble on the pavement.
Lifted 10.5" inches on 35s
4" inch suspension lift kit ( Tuff Country 14045KN )
3.5" torsion bar crank on adjustable Suspension Maxx torsion keys
3" inch body lift kit by Performance Accessories
Wheel size is different but the tires size and lift is about the same your looking for
1 - 8 of 8 Posts
