1 - 14 of 14 Posts
youre going to need to measure....
is there one that might line up perfectly? ....maybe, but you are diving into somewhat uncharted territory since there are not many guys that have a 4l80e in our trucks.
not saying it hasnt been done or that it could not be done.
your best bet would be to find a 1500 truck/suburban that was 2wd with 1330 size u-joints and then get that driveshaft cut down and balanced to whatever size you need.
just so you know long one pc drive shafts are limited to speed/rpm
that's why the 5.3 ZQ8's are 2 pc. it has something to do with
harmonics.
maniac mechanic
harmonics.
That should only be with the trucks with aluminum shafts. I rarely see steel ones catch a resonance. Aluminum though they will sing like a banshee when they do, my dads diesel van does this around 70mph.
It's weird what GM did with our driveshafts. I have seen a truck identical to mine with an aluminum shaft and my truck came with a steel one from the factory. Seems like they used a few manufacturers to produce them who used different materials.
I have the 4L80 as well, I took a aluminum shaft from an Express or something and cut it down but side by side with the original steel shaft I could have just changed the yoke. Rather have the aluminum shaft though ...
i have a custom aluminum 4" in my 2 door. id personnally have one made. the oem ones have issues due to them being thin wall. mine cost 482 bucks and they dared me to break it knowing im shooting for 1khp and actively been pushing 750 plus whp for over 3k street miles and several track outings. just spend the coin and save the safety risk
1 - 14 of 14 Posts
