1 - 2 of 2 Posts
So I'm about to start a long build process on my truck I am building a 5.3 and swapping a t56 6spd out of an 98-02 camaro. Will the stock 5.3 harness and ecu semi "bolt in" or pretty much all work together? Or should I get a 5.3 colorado harness? Also if anyone has a place to get manual colorado parts that would be great. And v8 colorado motor mounts. Any input would be great thanks
@Steensland-racing86
Current Performance makes engine mounts for v8 conversions and harness modifications/custom harnesses. As for the ability to use a t56 with that (I believe E67 ECM) I'm not sure will be easy. I know I have seen in other threads it was suggested to use an E40 from SSR for swaps because they had a manual/t56 option but I am not sure if that applies to your situation.
1 - 2 of 2 Posts
