found some afteermarket 20"s for a newer ford, is the bolt pattern the same as on our trucks?
rims from c/k body trucks (silverados, sierras, tahoes, yukons, escalades, and avalanches) will also fit when the hub is bored out.no the only other truck wheels that fit out trucks are the H3 hummer....other than that they have to colorado/canyon specific
these will fit with a bore and anything from a hardbody/frontier (before they changed to the current body style) will fit without bore.... you can take the rims to a machine shop and have them fill and re-drill the holes but unless you want to spend 100+ a rim to do it then its not worth it... ive done it i put navigator rims on my frontier a while back but if you really wanted to you could bolt them on with hub adapters or my other friend just bolted them on with just a bore..... the difference is about 2mm (so when you bolt them on they have a 2mm deflection)... hes been running them for a year so far and nothing bad happened..but i dont recommend it...lolrims from c/k body trucks (silverados, sierras, tahoes, yukons, escalades, and avalanches) will also fit when the hub is bored out.
nissan titan/armada's also will fit when hub is bored out.
