1 - 6 of 6 Posts
MTS Crew
Please read and follow the rules.
Submitting an entry for Photo Of The Month is easy!:
  • Upload or link a good quality (minimum 800x600) non-photoshopped (unless it is part of the contest, ie. HDR) image to the Photo Of The Month Contest Entry Thread
  • You must include the EXIF data from your image to show proof of photo ownership
  • If you are submitting a converted or scanned image from a negative, printed photo or slide, please snap a photo of the actual negative, photo or slide and a legible note with your user name and date to show proof of ownership.
Prize for the winner:
  • Bragging Rights!
Follow the Contest Rules:
  • You must be the owner of the image you are submitting.
  • 1 image will be accepted for entry. You will have time to change your image until the entry deadline.
  • We will not consider low quality images
  • We will not tolerate any pornographic content
  • No Photoshopped pictures unless it is part of the contest! Cropping is accepted.
  • Past winners may enter again every month.
  • You will NOT be up for voting if you get banned.
  • You must have at least 100 posts to vote
  • You have to have been a member of the forum for 1 month at the time that entry closes to enter.
***No Discussions in the entry threads please. Just the link/upload of your photo submission in the entry thread. ***
When to enter for POTM:
- Entries for POTM are taken monthly to give you time to take the photos. Voting will start on the 15th of every month and will continue through the following month. The winner will be announced on the 15th of the following month.
Yes, you will still be able to vote if you have less than 100 posts, but, if you do vote, your vote will be removed from the poll. Polls are checked everyday, and will be amended accordingly. The reasoning behind this action is the same as TOTM.
8/2013 Theme is YOUR BEST SHOT!
A CREATIVE/ARTISTIC image displaying YOUR BEST SHOT. The image must be a quality, well thought out image of anything that you feel could be a gallery hanging.
Enter your BEST SHOT! Entries will be accepted until 9/14/2013 @ 11:59pm Pacific Time. Any entries after that time will not qualify and this thread will be locked. The polls will open 9/15/2013 after 12:00am Pacific Time. Good luck and have fun with it!
Nation Lurker
EXIF Data attached
all your base
Code:
Make NIKON CORPORATION
Model NIKON D3100
Aperture 7.1
Exposure Time 25
Lens ID AF-S DX VR Zoom-Nikkor 18-55mm f/3.5-5.6G
Lens Spec 18-55mm f/3.5-5.6 G VR
Focal Length 18.0 mm
Flash No Flash
File Size 4.4 MB
File Type JPEG
MIME Type image/jpeg
Image Width 4608
Image Height 3072
Encoding Process Baseline DCT, Huffman coding
Bits Per Sample 8
Color Components 3
X Resolution 300
Y Resolution 300
Software Ver.1.00
YCbCr Sub Sampling YCbCr4:2:2 (2 1)
YCbCr Positioning Co-sited
Exposure Program Manual
Date and Time (Original) 2012:07:28 22:40:36
Max Aperture Value 3.5
Metering Mode Center-weighted average
Light Source Manual
Color Space sRGB
Sensing Method One-chip color area
Custom Rendered Custom
Exposure Mode Manual
White Balance Manual
Digital Zoom Ratio 1
Focal Length In 35 mm Format 27 mm
Scene Capture Type Standard
Gain Control None
Contrast Normal
Saturation Normal
Sharpness Normal
Subject Distance Range Unknown
Quality Fine
F Number 7.1
Exposure Compensation N/A
Focus Mode Manual
Flash Mode Did Not Fire
ISO Setting 200
ISO 200
Compression JPEG (old-style)
Orientation Horizontal (normal)
1 - 6 of 6 Posts
