1 - 10 of 10 Posts
912A654 Detroit Truetrac Limited Slip GM Chevy 8" Rear 3.27 & Up and 4:10 R&P
912A654 Detroit Truetrac Limited Slip GM Chevy 8" Rear 3.27 & Up. This is basically NIB. I pressed on the bearings for installation and after I tore everything down to install realized my V8 Colorado had a 8.5" rear end. $385 shipped US obo.
Link: https://www.drivetrainamerica.com/p...trac-limited-slip-gm-chevy-8-rear-327-up.aspx
12471429 GM 8 4.10 Ratio AAM OE Ring & Pinion Gear Set. Same story as above but never even pressed bearings on. $190 shipped to US obo.
Link: https://www.drivetrainamerica.com/p-858-12471429-gm-8-410-ratio-aam-oe-ring-pinion-gear-set.aspx
Re: 912A654 Detroit Truetrac Limited Slip GM Chevy 8" Rear 3.27 & Up and 4:10 R&P
Do you have bearings for the 4.10s? And if so will that be included in the 190? Interested.
No bearings for the pinion are included. Thanks
Discussion Starter · #5 ·
I have plenty of feedback from sales on eBay under user name s1055 and on rctech.net under user name cleblanc. All 100%. I don't sell junk, nor am I a scammer. Thanks
Discussion Starter · #6 ·
Truetrac sold! Gears still available
Discussion Starter · #8 ·
Gears are still available..
Discussion Starter · #10 ·
Gears are still available, differential is sold.
1 - 10 of 10 Posts
