1 - 11 of 11 Posts
My a/c completely isn't working, it was absolutely fine yesterday now today none of the dials work or anything, do you think it is a switch problem? A fuse? something?
None? Not even 4? If 4 works and nothing else then its the resistor under the dash... but you said none so im assuming this is incorrect.
you are correct about being incorrect, None of them work at all i checked the plug that was in the other thread and nothing is burnt.
Well all I know is when that part craps out in my truck I can still hear the a/c start and stop to run and I can still turn it on and off with the controls usint either 0 for off and 1-4 for on(just no blower except on 4) see if that works...
I opened the hood and had my dad listen for the a/c going on and got nothing its like its not receiving the signal to turn on or something.
This happpened to me leaving the golf course Sunday. It was raining like hell, I stopped to get a "road soda", when I got back in the A/C wouldn't work. None of the settings, nothing! I started driving and it slowly came back on. About 3 miles down the road everything was fine and I haven't had a problem since...WTF???
Air conditioning is overrated anyway.
:lol: Coming from someone that might need A/C twice a year.........
Not a GM mechanic but in home a/c's there is a delay to insure the system equalizes before startup otherwise it ends up being a hard start situation which is bad for the compressor unless setup for it. I just got my 2007 Colorado so I'm a newb....just throwing out some probably useless info.
1 - 11 of 11 Posts
