1 - 6 of 6 Posts
I will add to this as people provide them, please post below and you will be credited for helping add to the data base.
Name / Color / Polarity / Location
Battery WHITE/BLACK (+) Ignition Switch Harness
Ignition 1 WHITE/GREEN (+) Ignition Switch Harness
Starter 1 (+) Ignition Switch Harness
Domelight Super WHITE (-) At The Body Control Module PIN # A46
LF Latch GRAY/BLACK (-) At The Body Control Module PIN # A32
- Note Double isolate diode on each wire to prevent falsing.
RF Latch GREEN/BLACK (-) At The Body Control Module PIN # A38
LR Latch BLUE/BLACK (-) At The Body Control Module PIN # A44
RR Latch BLACK/WHITE (-) At The Body Control Module PIN # A39
Parking Lights BROWN (+) At The Headlight Switch OR PIN #A48 IN A GRAY CONNECTOR At The Body Control Module
Low Crr Pk Lights BROWN/WHITE At The Headlight Switch OR PIN #A7 IN A GRAYCONNECTOR At The Body Control Module
Remote Start
Accessory 1 WHITE/RED (+) Ignition Switch Harness
Tachometer (AC) UNCOMMON WIRE AT THE COIL PACK OR AT ANY FUEL INJECTOR
Low Crr. Pk Lights BROWN/WHITE At The Headlight Switch OR PIN #A7 IN A GRAY CONNECTOR At The Body Control Module
Brake Lights
LIGHT BLUE (+) At The Brake Pedal Switch
Reverse Lights LIGHT GREEN (+) Under Hood, Fuse Box
Horn GREEN (-) AT THE STEERING COLUMN HARNESS OR At The Body Control Module PIN # A25 IN A GRAY CONNECTOR
Doorlocks/Windows
Power Unlock DARK BLUE (-) IN THE DRIVERS KICK PANEL OR PIN A12 IN A BLACK PLUG At The Body Control Module
- Note TO UNLOCK JUST THE DRIVERS DOOR ONLY, PULSE THE WHITE WIRE AT THE BCM, PIN # A12
PowerLock LIGHT BLUE (-) IN THE DRIVERS KICK PANEL OR PIN A11 IN A BLACK PLUG At The Body Control Module
Driver Mtr Unlock TAN (REV) At The Lock Switch (Drivers Door)
Driver Mtr Lock GRAY (REV) At The Lock Switch (Drivers Door)
Pas Mtr Unlock TAN (REV) At The Lock Switch (Drivers Door)
Convenience
All Hazrd Lights WHITE (-) At Hazzard Switch OR At The Body Control Module
PIN # A48
Parking Brake LIGHT BLUE (-) AT Parking Brake Switch
Module Locations:
Module 1 BCM - Located in the passenger kickpanel.
Lighting wires up front...
orange = positive (low beam and high beam)
Blue = ground (lows)
Pink = ground (highs)
Purple = positive (fogs)
black - ground
thats all i could give ya though
If anyone has any questions I have a Power Probe and can go poking around. Just let me know which wires you are curious about.
i need to find the best way to get a +12v signal when the truck is in reverse, as close to the engine compartment as possible.
Speakers:
Front LEFT Door: Tan (+); Gray (-)
Front RIGHT Door: Light Green (+); Dark Green (-)
Left Rear: Brown (+); Yellow (-)
Right Rear could have same as left rear or: Dark Blue (+); Light Blue (-)
1 - 6 of 6 Posts
