I am having major troubles with the brakes/ABS Worked fine until I swapped in the T56, don't know if its related or just a bad coincidence? I get both the brake, and ABS lights on, and fault, brakes displayed on the cluster. Pedal feels softer when light is on, and seems like ABS wont kick in at all, when the code is set.
ABS? I Get a B0222 or C0222 rear channel in release to long?
Dealer says that is a wheel speed sensor, or that its driven in mud or snow. Well it sets on dry pavement, and low speed while cornering, either coasting or braking. Also the pedal pulses like mad, the minute you touch the brakes, the abs kicks in at any speed under about 30 mph.
Could it be the T56 17 tooth reluctor does not have enough resolution to pick up well at low speeds for the Colorado's ABS system? Automatics, and Colorado Ma5 5 speed, and SSR T56 all use a 40 tooth reluctor for better resolution.
How do I determine what wheel speed sensor it is? Or if its the V.S.S which doubles as the rear wheels speed sensor for the ABS
Is it a tuning issue the way I have the speedo settings? I kept the settings the same as they were with the V8 and stock 5speed. Al I did was change the reluctor from 40 to 17? The speedo seems accurate? Is there something else I need to change?
