1 - 4 of 4 Posts
2011 GMC CC 4wd Z71
So yesterday I had the left rear tire plugged from a nail puncture. Drove it home less than a mile and parked overnight.
This morning at about 3 miles into my commute the truck had no power at acceleration and all three codes flashed with chimes. I pulled to the side and shut off the engine. The codes remained at startup. So I went on in to work.
Afterwards, the codes have remained along with the no power upon acceleration.
So, did removing the wheel from the left rear cause these codes to flash? And how do I get rid of them?
List the codes . I can't see them from where I'm at . :unsure:
My apologies for phrasing it as “codes”. What I intended to say was all three codes (ABS, Traction, Stability) were activated as evidenced by the lights in the dash. Unfortunately I do not know what the codes are but the truck is now at my local GMC dealer. I will report back with an update. Thank you for the time.
1 - 4 of 4 Posts
