1 - 3 of 3 Posts
Needed some help
Have a 06 reg cab 2.8l with 130k miles
I recently replaced both speed sensors bc the abs/break light would come on at times and breaks would pulse when applied. when I removed my old ones notice the inside was realy dirty and looked like rust debree. Changed them out.
Took the truck out for a test drive brake pedal went down and abs/break light came on.
Would a bad hub bearing cause this to keep the brakes faulting ?
I know with a scan tool it I can diagnose this faster
Just wanted some advise from you guys
Thanks
Needed some help
Thanks
Mine is doing the same thing...just had new brakes and rotors put on my truck and my brakes are pulsing, also had to put new wheel speed sensors. My abs light was on before I put it in the shop but didn't pulse, after I get it back from the shop it goes on and off but my brakes pulse.
1 - 3 of 3 Posts
