I have not been around here for many years and when I was I usually went to Coloradofans. Any way, I now have a long standing problem that is getting worse and In an area where I have never worked.
I have a 2005 Z71 2wd Colorado with a 3.5. For many years it had a highly intermittent ABS sensor problem. Initially it only occurred when it was 85 to 90 degrees outside, or If I was towing a heavy load and lots stopping. There were never any codes stored but I would get ABS lights and traction faults. Over the years the failure temperature gradually lowered and now I am getting them with temps below freezing and not hauling a load.
I need to use the truck with 2 axle trailer for several trips of 200 miles or so, and my daughter will be driving it, not me. So it is time to fix it. Today I and another Colorado owner jacked up the truck looking for obvious problems with the front wheel sensors, brakes, and tires. I did find some accumulated flakey rust inside the mounting ring that contains the front sensors. Without logging errors we do not know which one is causing the problems. We cleaned out all of the accumulated rust in that area and cleaned the face of the magnetic wheels that rotate in front of the sensors. I thought this might take care of it.
I got 2.5 miles down the road and I had the problem on a cold truck with outside temps at around 28 degrees. I went back to my friend's unheated pole barn and we looked at again. Hubs and bearings and tires are fine. So I really do not want to pull the hubs just to replace both sensors. I have a new pair of sensors that I could install but can not figure out how to replace them without pulling the spindles / hubs. The reason we are leary of pulling the hubs is my friend did to his at around 250 K miles. They were impossible to get out . He had to use a 4 ton porta power to get them out. We went to borrow that porta power again and it is broken. I do not have a source for another one with buying one.
So now my question. Is it possible to get those sensors out without pulling the hubs first? If so, how is it done? This is a 2WD Z71 and uses the same parts as a 4WD Colorado except for no front drive shafts and CVJs. It has torsion bar front suspension.
Any thoughts or ideas would be greatly appreciated.
