1 - 5 of 5 Posts
Looked for a bit but could not find anything set in stone.
As for the crankcase breather plugged into the bottom of the box, can you remove the box and just throw a filter on this tube? If so on the front of said box there is a vacuum sized hose (although it doesn't seem to be a vacuum hose) can I plug it up with no check codes going off?
I ask because I bought a Air Raid Quick Fit kit and now want to make it true cold air. I have the stuff to do it just need to know if I can plug and filter said hoses without complications. Thanks!
do not just plug it up! i would say your best bet is to try and connect it directly to the intake, but i have seen it just left open: its a fuel system vent thingy. the crankcase breather filter should work out, but connecting to the intake is the best way for this too.
I had a breather on my last car. Oil was everywhere under the hood and I noticed no benefit. I'd say leave it the way it is and save yourself the hassle of having to clean the oil from the engine bay all the time.
Discussion Starter · #5 ·
I wanna remove it cuz that box is just another restrictor. I have dirtbikes and every bike I get I do a crankcase mod to let it breathe....is there a point to have hot air going back into the intake? As for the oil I would filter it the put it in a mini can to catch the oil so no problem there.
I thought that front plug was a vent but wasn't sure there, good knowledge thanks.
I only ask this because I don't wanna spend more money on a new cold air when I have the stuff to make my quick kit into a true cold air left over from my previous chevy.
1 - 5 of 5 Posts
