I think that is what its called i am missing 2 on each side both opposite sides wasn't sure if it was a big deal if it keeps it in place or what
any info would help thank you.
On another note i was checking for any play anything underneath the outer tie rods ect... On the passenger side outer tie rod i can move back & forth as if i was going to use a wrench an take it off to replace,The driver side was a lot harder to move , Both do not move up an down.
Also the sway bar links?... had some play as well i could move back & forth with my hand.
is this amount of play normal or should it be replace..
