Ok quick question...I have a rockford punch HE2 12 inch sub and wanna up the power to it...DVC 4ohm have it ran in Paralell(sp) my amp does not have enough power to push it...(the amp keeps over heating) when I see this
2 x 200 into 4 Ohms
2 x 350 into 2 Ohms
1 x 700 into 4 Ohms
BlackMaxx High Dissipation Heat Sink for more effective heat dissipation
Illuminated BlackMaxx "M" on top-plate
Crunch MOSFET's for clean, reliable, high-speed, high performance output
G-Force Power Supply: PWM power supply instantly delivers maxx current
SEPP (Single Ended Push Pull) A/B Amplifier Operation
Bass Boost Circuit for Enhanced Bass Response
Versa Cross featuring Hi-Pass and Low-Pass Adjustments
High Level Amp Inputs for OEM Receivers without Preamp Outputs
Silver RCA Inputs
Silver RCA Outputs for Amplifier Daisy Chaining
Protection Circuitry guards against: current, short circuit, or thermal overload damage
is this the amp I need
thanx again for the help guys:salute:
2 x 200 into 4 Ohms
2 x 350 into 2 Ohms
1 x 700 into 4 Ohms
Silver RCA Inputs
