The install was relatively easy. The hardest part was cutting off the stock stab. bar brackets. And that was only cause I suck with a sawzall!! LOL Other than that, it's a simple bolt on application.
I will say this though, the instructions or I should say the picture of the upper ball joint spacers, suck ass. You can't really see how the spacer is positioned so you're left to use your better judgement. After messing with different mounting positions for about a half hour, I came to the conclusion that it didn't matter which way it went, the piece was symetrical. At least I thought so. I was going to ask others about it, but I haven't had any problems with mine so it must be on there right.
It's really not hard at all bro. Just dive right in! I did my whole drop (incl. the rear blocks) by myself in about 2 hrs. And that was including the time I wasted with the upper bj spacer and my sloppy sawzall work! But I did have it on the lift at work and all my air tools.:355:
