I have a crew cab 4x4 with the 4l60e auto trans and im having problems with the trans not shifting into 4th gear. It is only doing this when the truck as been sitting for 8 oro hours either when I start it up in the morning or when I get off of work it does this. It will hold onto 3rd gear until it the truck gets up to temp and then it willshift into 4th gear. It isn't shifting hard nor does it slip out of gear. It just willnot go into 4th until the truck gets up to operating temperature. After the truck reaches running temp the trans operates flawlessly. The truck has 105k miles on it and 3 months ago I did a fluid and filter change on the tans. The fluid that was removed was still red and there was no need for alarm there. Also I added some sealrestore to the new fluid I put back in.
Please if you have any suggestions as to why my trans is acting this way I am open to all suggestions as to how to fix the problem.
Thanks and all help and advice is appreciated.
Brad,
Lancaster, SC:355group:
Brad,
