Axle asm/rear 8.625 ring gear part 2 differential
4K views 0 replies 1 participant last post by  rshadd
AXLE ASM/REAR 8.625 RING GEAR PART 2 DIFFERENTIAL; AXLE ASM/REAR 8.625 RING GEAR PART 2 DIFFERENTIAL/LOCKING; DIFFERENTIAL/LIMITED SLIP
(G80, EXC AXN); (G80, EXC AXN,Y91); (G80,EXC (AXN)); (GT5,G80,EXC (AXN)); (GU4,GU5,GT4,G80); (GU6,G80); (GU6,G80,EXC (AXN)); (LH8/5.3L, G80); (LH9/5.3P, G80); (LIMITED SLIP G80);
NOT FOR IDENTIFICATION 9.5" LIGHT DUTY BEAM 9.5" LIGHT DUTY BEAM(AXN);
NOT FOR IDENTIFICATION HYBRID AXLE HYBRID AXLE(AXN);
NOT FOR MERCHANDISED PKG LUXURY EDITION LUXURY EDITION PKG(Y91)
Box Sizes: 5-8; 6-6; 8-0;
Capacity: 1/2 TON; 3/4 TON;
Drivelines: 2WD; 4WD; AWD;
BRK: BRAKE VAC POWER, 17" DISC/DISC, W/VSES, 7700 LBS 7700 LBS VAC PWR BRAKES W/VSES(JD9); BRAKE VAC POWER, 17" DISC/DRUM, W/ABS, 7, 000 LBS 7,000 LB VAC PWR BRK(JF3); BRAKE VAC POWER, 17" DISC/DRUM, W/RWAL, 6,400 LBS 6,400 LB VAC PWR BRK(JF7)
CHP: "OFF ROAD" CHASSIS PACKAGE 'OFF ROAD' CHAS PKG(Z71); CHASSIS PACKAGE,INCREASED CAPACITY CHAS PKG(Z85); SPORT CHASSIS PACKAGE SPORT CHAS PKG(ZQ8)
ENG: ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 5.3L, SFI, V8 OHV, CYL DEACTIVATION, IRON, GM 5.3-0 FLEX FUEL W/CYL DEACTIVATION(LMG); ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 6.2L, SFI, ALUM CYL DEACTIVATION, GM 6.2 W/CYL DEACTVN(L94); ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 6.2L, SFI, ALUM GM 6.2-2(L9H); ENGINE FLEXIBLE FUEL,(GAS/ALC),8 CYL,5.3L,SFI,ALUM CYL DEACT,GM 5.3-3 FLEX FUEL W/CYL DEACTVN/AFM(LC9); ENGINE GAS, 4 CYL, 2.9L, MFI, L4, ALUM, VVT, DOHC, GM 2.9-9(LLV); ENGINE GAS, 5 CYL, 3.7L, MFI, L5, ALUM, VVT, DOHC, GM 3.7E(LLR); ENGINE GAS, 6 CYL, 4.3L, GEN 5, SIDI, V6, VVT, OHV, E85 MAX, ALUM 4.3 (LV3); ENGINE GAS, 8 CYL, 5.3L, SFI , E85 MAX, ALUM, GM 5.3 (LH9); ENGINE GAS,8 CYL,5.3L,SFI,IRON,CYLINDER DEACTIVATION,GM 5.3J W/CYL DEACTVN(LY5)
HPS: HYBRID PROPULSION ELECTRIC, AHS2 AHS2 HYBRID ELECTRIC PROPULSION(HP2); HYBRID PROPULSION ELECTRIC, HYBRID ELECTRIC PROPULSION(HP2)
OTHER: CONTROL ACTIVE BRAKE ACTIVE BRAKE CONTROL(JL4); IDENTIFICATION 9.5" LIGHT DUTY BEAM 9.5" LIGHT DUTY BEAM(AXN); PERFORMANCE PACKAGE ENHANCED TOWING ENHANCED TOWING PERF PKG(NHT)
PAX: AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
RAX: AXLE,REAR,3.08 RATIO 3.08R(GU4); AXLE,REAR,3.23 RATIO 3.23R(GU5); AXLE,REAR,3.42 RATIO 3.42R(GU6); AXLE,REAR,3.73 RATIO 3.73R(GT4); AXLE,REAR,4.10 RATIO 4.10R(GT5)
SGR: LUXURY EDITION OPTION,"LE" LUXURY EDITION/"LE" PKG(Y91); MERCHANDISED PKG LUXURY EDITION GMC ENVOY DENALI LUXURY EDITION PKG(Y91); MERCHANDISED PKG LUXURY EDITION LUXURY EDITION PKG(Y91)
TRN: TRANSMISSION AUTO 6 SPD, HMD, 6L-80 6-SPD AUTO TRANS(MYC); TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD AUTO TRANS(M30)
VEA: INTERIM CONTROL CHANGE INTERIM CONTROL CHANGE:REFER TO VEH OPT LABEL FOR VERIFICATION(CNV)
http://parts.nalleygmc.com/showAsse...=19456&ukey_trimLevel=25505&searchString=rear
You have insufficient privileges to reply here.
