some of the stuff I had to do to get it to lay flat
make a tunnel for the drive shaft
section the exhaust y-pipe to tuck it up tighter
counter sunk the tranny crossmember bolts to be flush to the frame
found that the drivers side front tire hit the wiring harness and kept it from laying out so I moved it up about 1" and to the side about 2", and also recessed it into the firewall about 1". gave me plenty of clearance (the black stuff is seam sealer)
front tire tucks up nicely now
and the pay off, rocker down flat :th_woot:
